100 octane fuel...
Old Oct 22, 2003 | 09:36 AM
Unriced's Avatar
Unriced
Default 100 octane fuel...
Sunoco is selling 100 octane fuel in my area and Im curious.
What can I expect when I put some in my tank? It's 4.89 a gallon.
Anyone?
Old Oct 22, 2003 | 11:32 AM
bogus's Avatar
bogus
Default Re: 100 octane fuel... (Unriced)
a lighter wallet... and hard cold starting.
100 octane will not hurt anything, but the L98 is not tuned high enough to take advantage of the extra octane.
100 MIGHT help an LT1 or LT5... but it won't amount to much...
Old Oct 22, 2003 | 11:37 AM
CFI-EFI's Avatar
CFI-EFI
Unless it eliminates knock counts, it should slow you down, slightly. Good luck, and...
RACE ON!!!
Old Oct 22, 2003 | 11:54 AM
jfb's Avatar
jfb
You will experience fewer knock counts and a thinner wallet. But....using that fuel, you could advance the timing and you will see more hp!
Old Oct 22, 2003 | 12:38 PM
Unriced's Avatar
Unriced
Default Re: 100 octane fuel... (jfb)
It looks like the thinner wallet equates to less weight which has to mean
better performance somewhere... Wait, my wallets thin enough already... :(
I'll skip out on the gas...
Old Oct 22, 2003 | 12:44 PM
scorp508's Avatar
scorp508
Save your $$. :)
Old Oct 23, 2003 | 01:54 AM
black_89_vette's Avatar
black_89_vette
Default Re: (scorp508)
Could you advance your timing to like 12 with the higher octane eliminating ping?
How high could you safely advance your timing with this high octane?
Old Oct 23, 2003 | 04:51 AM
neat's Avatar
neat
Default Re: (black_89_vette)
The higher octane gas won't help most people. Most cars, stock or lightly modded, can see more timing than they need with 92 octane. Try getting some 92 octane the next time you're on a dyno. Advance the timing until it pings, or quits making power. My bet is you'll stop making power before it detonates.
If you aren't running N20, forced induction, or high compression, 92 is enough.
As to how far you could advance the timing with the high octane gas, every combo is going to be different. Elevation will play a part, as well as weather conditions that day. There is no set, concrete number.
[Modified by neat, 2:53 AM 10/23/2003]
Old Oct 24, 2003 | 12:47 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
LoL Unocal 76 sells that "racing fuel" at a station close to where I live. My engine's not tuned well enough to take advantage of it the way it should be. My mechanic told me not to use it cuz it could f*** up my engine...ie rings , pistons, valves....u name it. He said you gotta have engines designed for that kind of octane to be able to use it without problems or heavy repairs. I'm sure the stuff is good for those that can handle it, but it's kinda like puttin rocket fuel in a lawnmower....although these "cars" are often deemed rockets.....one must never forget that that's actually a metaphor. LOL. :yesnod:
Old Oct 24, 2003 | 02:41 AM
BowTieBlood's Avatar
BowTieBlood
Just use the premium :cheers:
Look out, octanes always start an argument around here :yesnod:
Old Oct 24, 2003 | 09:09 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
You can get 100LL (Low Lead) at the airport for just over 2 bucks a gallon. :cheers:
To 100 octane fuel...
