L98 mod question?
You think your opinion matters more because you took your heads off and ported them, bullsh**. Ive seen the sumbitches off the car, and performance-wise they aint gonna get you anywhere you want to go in the long run.
And if you think half the stuff I say is wrong, prove it. Go find 10,000 incorrect posts. You wont.
If you always know the correct answer to everyones question, why dont you get on here and answer them? I apologize to anyone whom I have wholly incorrect information, but as I proved you wrong again a couple days ago with my 86E having a 1-piece, youll see that I'm only wrong a small percentage of the time.
[Modified by vader86, 9:43 AM 10/25/2003]
No it seems to me that flyersfan has made it his mission to nitpick with my posts lately, and find every possible way in which to call me wrong. I dont mind disagreement, but when you say i'm wrong, without showing me evidence to prove the contrary....you should just say that you believe the heads are good for certain power goals and not say someone else is flat out wrong.
Lift .100 .200 .300 .400 .500 .600
Stock 44 101 155 182 196 202
Ported 58 115 165 191 202 208
As you can see, there is some gain to be had, especially at the lower lift stations. Now if you can do this with a minimal amount of money invested, this is far from a worthless idea. I said you were wrong because you said it was worthless to port them. While it may be worthless if your ultimate goal is a monster motor, it is definitely NOT worthless to the many people here who are looking for more power on a budget. I liken it to Large Tube Runners. Definitely better than stock but can't hold a candle to the Superram or Miniram. Does that Make LTR's worthless? No. But they will limit you down the road, just like cast iron heads will limit you down the road. But for the time being they are a definite improvement over stock.
