84 rear upper/lower control arm bushing replacement
Brimis
It is pretty straight forward, just labor intensive. Well worth the effort. afterwards you will want to do the rear also. Shoot me an email if you have questions or problems.
FP
RACE ON!!!
RACE ON!!!
I did my rear a couple of years ago and it wasn't difficult. the hardest part was drilling out the oil bushings.
When I asked, I received mixed responses on whether or not to use polyurethane bushings; some said yes, others no. I went with them.
Haven't had a problem yet.
I did install zerk fittings on each bushing by drilling and tapping holes and screwing in the grease fitting. So far the bushings have remained quiet, but with all that high compression exhaust sound, who could tell anyway.
I only had to use my bench vice, electric drill and the necessary wrenches/sockets to make the swap.
Hope this helps.
Jake
RACE ON!!!
[Modified by CFI-EFI, 1:04 PM 10/24/2003]
I had a HELL of a lot more trouble with the support rod bushings in the rear. Again, getting everything to line up on reassembly. Nothing major, just a couple of colorful words.
I also replace rear wheel bearings and half shaft U joints while I was at it. It really helped the way the car handled. Just be sure to have the car aligned when you are done.
Drop me a note if you run into any trouble. I am quite familiar with the rear suspension now
OH....almost forgot one VERY VERY important tip. Put a piece of masking tape over the hole in the frame of the car where the control arm bolt is, or you WILL drop the nut in there and you WON'T be able to get it back out. Alternately, use vice grips instead of a wrench to back up the nut so you don't lose it forever into the frame. I was lucky enough to read this tip from someone else prior to doing mine. This saved me from what would have been a PITA. Just a word to the wise
[Modified by Frizlefrak, 2:40 AM 10/25/2003]
