Rocker arm studs
Old Oct 23, 2003 | 06:41 PM
bstirn's Avatar
bstirn
Default Rocker arm studs
Are the rocker arm studs the same for an LT1 as an LT4 . My Roller Rockers came with the bolts want make sure everythings ok before I start working on It . Thanks
Old Oct 23, 2003 | 06:59 PM
FD2BLK's Avatar
FD2BLK
Default Re: Rocker arm studs (bstirn)
No the LT4 used 10mm tapered studs and the LT1 used 3/8 studs. If you have true LT4 rockers then you have to use the LT4 studs and follow the torque sequence to install them. If they are the LT4 retro kit for the LT1 then they are the samr rockers as theLT4 but they have the 3/8 holes so they can be mounted on the LT1 heads. I have the LT4 studs and rockers on my LT1 and they work fine with my LT4 hotcam. The only negative to the LT4 rockers is they are non adjustable and when I installed them on my motor it went about 3/4 of a turn past zero lash before they met the torque spec. I usaly set my valves at only a 1/2 turn past zero when they are adj. but 3/4 is still ok.
