iam preparing to replace my spark plugs in my 94 C4 vette (67k) i presently have auto lite plantiums and i'd like to replace them with another 100,000 spark plug, any opinions? any reconmendations? or just stick with the auto lite or maybe move up to the auto lite double plantium plug?
thanks boonie
I switched to NGK Iridiums and Taylor 8mm Spiro Pros. At about 70K I had the Chevy put in new wires and plugs (both AC/Delco). Within a little more than a year I was getting a low rpm miss and it ran poorly. After reading a lot on this subject here and asking questions I chose to switch. Except this time, I installed them. I've been very pleased with the results, I've eliminated the miss and she runs very well. I don't have any data to support it but it feels much more responsive. Initially I had a problem with the coil wire, it wouldn't snap on the opti side. But one call to Taylor and in two days I had a new replacement.
With the iridiums you don't gap them, they are preset at the factory. Its a micro tiny electrode.
Oh almost forgot. The AC/Delco platinum plugs have a little small puck under the ground strap, and they can come off. I believe it was my #3 plug was missing the puck. After only 20K. And the AC wires seem to be shorting out against the oil dip stick.
Well as I said I'm very happy with the new setup. So I'll recommend them.
