100 TNT Spray without retarding timing?
Old Oct 23, 2003 | 08:12 PM
red-y's Avatar
red-y
Default 100 TNT Spray without retarding timing?
What is the risk on a stock bottom end? :skep:
Old Oct 24, 2003 | 01:14 AM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: 100 TNT Spray without retarding timing? (red-y)
You should have no problem spraying a 100 shot without taking out timing. I know a few guys running a 150 shot without pulling out timing at sealevel. I haven't pulled out timing with my 150 shot... but at our elevation(DA 5500-8500ft) we can run more timing. A 100 shot really requires nothing different, and is very safe.
Old Nov 6, 2003 | 12:08 PM
dizwiz24's Avatar
dizwiz24
No problem,
Ive done it my 93 hotcam 6spd many a times. I originally wanted to run a MSD digital 6 so it would retard timing on spray, but was tired of the MSD unit failing. So I chose to run without it.
Ive even looked at knock retard, etc. while doing that. No problem with anything. 0 degrees knock retard.
Just run good gas.
Old Nov 6, 2003 | 08:43 PM
red-y's Avatar
red-y
Default Re: 100 TNT Spray without retarding timing? (dizwiz24)
Thaks for the replies. I am glad to see that someone else will step up and say that MSD is not reliable. After four units I am convinced.. :cheers:
[Modified by red-y, 7:44 PM 11/6/2003]
Old Nov 8, 2003 | 09:32 PM
TIMSPEED's Avatar
TIMSPEED
Ive even looked at knock retard, etc. while doing that. No problem with anything. 0 degrees knock retard. Just run good gas.
When you say "good gas", are you meaning 100 octane, or what? The highest octane we can get here (without mixing) is 91, but I can also get 100 (without mixing) in CERTAIN places...
Old Nov 10, 2003 | 07:16 PM
red-y's Avatar
red-y
Default Re: 100 TNT Spray without retarding timing? (TIMSPEED)
I think that means mixing at the track with racing fuel. At the pump the highest we can get in Texas is 93 octane. :steering:
To 100 TNT Spray without retarding timing?
