Z51 shocks
Old Oct 25, 2003 | 09:38 AM
9T3JIM's Avatar
9T3JIM
Default Z51 shocks
With the extra unsprung weight on the front end coming from AFS 9-1/2 rims, bigger tires and the C5 brake upgrade, the front end seems seems to have more wheel rebound than before when everything was stock. Will putting Z51 shocks on the front help keep the tires planted to the road better?
Old Oct 25, 2003 | 08:48 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Z51 shocks (9T3JIM)
I thinks so! but let me explain, I have done things incrementally so I can't be sure what started whe.
I have always run the Z 51 on my 88 Z52.
Two years ago, with otherwise stock set up, I was getting inside wheel lift under hard cornering (tail of the Dragon)
This year installed y2k wheels, C5 brakes, new Z51 shocks (old ones wore out in 25000miles) and 30mm front, 24 mm rear sway bars.
Same Tail of the Dragon, faster thru the corners and no wheel lift.
I think the sway bars my have has the most to do with it
:seeya
Old Oct 26, 2003 | 09:14 AM
9T3JIM's Avatar
9T3JIM
Default Re: Z51 shocks (jackdaroofer)
You bring up a good point about your shocks being wore out after 25,000 miles, I have 21,000 on my car but being a 93 they are 11 yrs old and they appear to be in good shape but who knows. I actually noticed the difference after putting the new rims and tires on and then after putting the C5 brakes I noticed that it seemed to be little more pronounced.
Old Oct 28, 2003 | 05:52 PM
9T3JIM's Avatar
9T3JIM
ttt
Old Oct 29, 2003 | 09:25 AM
HeeHaw89's Avatar
HeeHaw89
:seeya
jack - are your sway bars tubular or solid, f/r? Did ride quality change much?
Reason I'm asking is I have a FE1 equipped 89 and was considering upgrading to those bars to get a little more g's in the corners w/o sacrificing ride quality.
Old Oct 29, 2003 | 04:01 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Z51 shocks (HeeHaw89)
:cheers:
Bars are solid, not tubular.
Ride may be a litle "harder", but not noticeable or objectionable.
check out vettenut.org/susp_chart.html for different years and specs
I found that when I went to the 30 in front, I had to modify vertical links to be sure they remained "vertical" Otherwise, they acted more like a spring than a link.
Jack
Old Oct 29, 2003 | 04:14 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
You need to study that chart a little better.
Old Oct 29, 2003 | 06:13 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Z51 shocks (Jeffvette)
:cheers:
I'm sorry....your point is?
To Z51 shocks
