2 little questions
Old Oct 27, 2003 | 07:57 AM
cyberblast's Avatar
cyberblast
Default 2 little questions
Hi
Sorry for this those stupid questions.
First, the switch for my fog lights should have 3 states, i think. on this switch, at the right is a white point, in the middle nothing and on the left the symbol of the fog light. but its impossible to tilt the switch to the "left state". ok, i ordered a new switch, because i thouhgt its damaged. but with new new switch i've got the same problem? whats wrong?
my other question: how to verify the the model year of my corvette? in my vehicle document of identification i can see the date of first entry in circulation, this is february 88, but maybe my vette is a 87' model?
thanks
martin
Old Oct 27, 2003 | 08:32 AM
bogus's Avatar
bogus
Default Re: 2 little questions (cyberblast)
argh. You have an export model, eh? With that left and right thingy that the Europeans used to much...
I have NO clue how that circuit is designed...
My only thoughts... make sure the relays are working ok. Look at your owners manual and check the fuse/relay section. It might help you.
Also, are all the bulbs good?
Old Oct 27, 2003 | 10:09 AM
JAKE's Avatar
JAKE
The 10th digit (alpha character) of the VIN tells you the model year of the car. In my case it is a 'G' which translates to 1986. Most of the Chilton/GM manuals show you a breakdown on the VINs, as to what each character means.
Jake
[Modified by JAKE, 9:10 AM 10/27/2003]
Old Oct 28, 2003 | 10:14 AM
cyberblast's Avatar
cyberblast
Default Re: 2 little questions (JAKE)
Thanks JAKE, so i've got a 87'.
bogus,
this is the switch i ordered, because i thought the old one was damaged because i couldn't change it to the state of the fog light. but the replacement (the new one) has the same problem. do you know what i mean? i can switch to the point, to the middle but not to the fog light sign, it's blocking. i've no idea why, it's very unlogic.
regards martin
Old Oct 28, 2003 | 10:18 AM
scorp508's Avatar
scorp508
I don't think the export models were any different than ours when it came to this. The switch is just saying "I'm a foglight switch, press the white point to turn me on."
Old Oct 28, 2003 | 10:19 AM
dwestsr's Avatar
dwestsr
my 86 coupe fog light switch works both left and right and the lights come on and off as they are supposed to. I don't know what is going on with your switch. does it rock both ways out of the car or just installed?
Old Oct 28, 2003 | 10:34 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: 2 little questions (dwestsr)
:iagree: my 87 has (left - ctr - right) positions... rocks to all three
Old Oct 28, 2003 | 10:41 AM
scorp508's Avatar
scorp508
Default Re: 2 little questions (vinnies87)
Ok why doesn't my '87 then? :lol:
Old Oct 28, 2003 | 10:53 AM
CFI-EFI's Avatar
CFI-EFI
Vinnie,
What are the functions in each of the three positions? Mine is simply, on/off. What does your switch do that mine/ours doesn't?
Cyberblast,
What "state" are you missing? If it rocked to all three positions, what would you expect from a third position that you don't have with the two?
Good luck, and...
RACE ON!!!
[Modified by CFI-EFI, 8:58 AM 10/28/2003]
Old Oct 28, 2003 | 10:58 AM
cyberblast's Avatar
cyberblast
Default Re: 2 little questions (scorp508)
scorp508, can you turn on the fog lights?
in switzerland its goin to be matandory turning lights on all the time in 2004 :o( i like my vette more without the lights open.
Old Oct 28, 2003 | 11:03 AM
scorp508's Avatar
scorp508
:yesnod:
In my car the switch has the foglight symbol on the left side and the dot (which has worn off) on the right side. Pressing the dot in turns on the fog lights. Pressing the foglight symbol side in isn't possible, its blocked as you say.
But... I do have to have the headlight switch at least in the parking light position for the foglights to work.
Old Oct 28, 2003 | 11:08 AM
cyberblast's Avatar
cyberblast
oh, i will check that out, maybe it's the same with my vette.
do all other 87' owner need to turn on at least the parking light? :crazy:
Old Oct 28, 2003 | 11:19 AM
Goody's Avatar
Goody
I was under the impression that you must have other lights on and not just the driving lights. Supposed to prevent owners from running around with just front illumination and no rear lights (CA lawsuit waiting to happen :crazy: ). I'm not positive on this, but I think I've read it on here before.
Old Oct 30, 2003 | 04:53 AM
cyberblast's Avatar
cyberblast
ok, i tried that with the other light, no reaction...maybe are the fog light bulbs bad?
To 2 little questions
