LT4 Compression Numbers?
Old Oct 27, 2003 | 11:41 AM
sinc93's Avatar
sinc93
Default LT4 Compression Numbers?
Does anyone know what the factory compression reading is for an LT4 with the stock 330hp cam? I did a compression check on my engine and it is coming in at around 200-205 per cylinder. The engine has about 35000 miles on it. Any numbers would be appreciated. Thanks
Old Oct 27, 2003 | 01:34 PM
Micky Davis's Avatar
Micky Davis
Default Re: LT4 Compression Numbers? (sinc93)
http://www.corvetteactioncenter.com/...96/lt1lt4.html
More info than you might have wanted to know.
Have a good'un...............
Old Oct 27, 2003 | 01:36 PM
sinc93's Avatar
sinc93
Default Re: LT4 Compression Numbers? (Micky Davis)
Thanks I'll check that out.
Old Oct 27, 2003 | 03:43 PM
GlockLT4's Avatar
GlockLT4
I believe the conversion of 10.8:1 into psi should get you around 210-220psi. I don't remember for sure though. Should be over 200 though.
To LT4 Compression Numbers?
