aluminum heads interchange ????
Old Oct 27, 2003 | 02:20 PM
ladystoy69's Avatar
ladystoy69
Default aluminum heads interchange ????
does anyone know what the differance is between the LT1 heads and the L98 heads is? and will they interchange? and what mods may be needed? please let me know, thanks :confused:
Old Oct 27, 2003 | 02:55 PM
STL94LT1's Avatar
STL94LT1
Default Re: aluminum heads interchange ???? (ladystoy69)
No, they won't interchange. Lt1 heads are a reverse flow coolant design, and L98's are a conventional coolant flow design.
Old Oct 29, 2003 | 01:33 PM
92corvette's Avatar
92corvette
Aren't you an Auto Technician?
Old Oct 30, 2003 | 03:48 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: aluminum heads interchange ???? (92corvette)
That doesn't make someone automatically know an obscure fact such as this.
The heads generally LOOK alike. They both fit SBC engines.
It's a valid question.
Did YOU pop out of the womb knowing EVERYTHING?Or do you just THINK you know everything.
Old Oct 30, 2003 | 03:55 PM
krivera's Avatar
krivera
Default Re: aluminum heads interchange ???? (VetNutJim)
my buddy kirk has a L98 block that had L98 heads and he is running LT-1 heads on it? so i dont know if it is not possible because my friend kirk is doing it?
Old Oct 30, 2003 | 03:58 PM
STL94LT1's Avatar
STL94LT1
Default Re: aluminum heads interchange ???? (krivera)
He may be running a modified LT1 intake on his L98. But, it isn't possible to run LT1 heads on a L98 block.
Old Oct 30, 2003 | 04:02 PM
bstirn's Avatar
bstirn
The LT1 they built in the 70s was not reverse flow that maybe what youre buddy has . Not like our 90s C4 LT1 .
Old Oct 30, 2003 | 04:04 PM
STL94LT1's Avatar
STL94LT1
Default Re: aluminum heads interchange ???? (bstirn)
:iagree: Good point, I had forgotten about those LT1's.
To aluminum heads interchange ????
