Engine running rough
Old Oct 28, 2003 | 08:52 PM
timallard's Avatar
timallard
Default Engine running rough
Having problems with my car. 89 L98
On the way home on Saturday the engine started to run a bit rough. So far I have checked/done this
Changed spark plugs.
Checked for spark
Checked Fuel pressure
Checked resistance and voltage at injectors. 1 injector had more resistance than the rest.
Checked for vacuum leaks
Checked for error codes (light hasn't come on)
Finally I changed the fuel filter today. It is a bit better but still not right.
What have I missed?
Any help would be appreciated.
Old Oct 28, 2003 | 09:10 PM
Sam Lam's Avatar
Sam Lam
Default Re: Engine running rough (timallard)
What were the resistance reading on the injectors? Assuming you have the stock Multec injectors, you should have seen about 16 ohms. Let me know what you found! My 89 is currently sick with bad Multec injectors!!!
Old Oct 28, 2003 | 09:11 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I have relatives in Brisbane.
Wish I was down there.
Guess that doesn't help you. Sorry.
Welcome to the forum.
tony
Old Oct 28, 2003 | 09:24 PM
timallard's Avatar
timallard
Default Re: Engine running rough (Sam Lam)
16 ohms yesterday when cold. Just checked again with the engine hot and they are 17 ohms except for No8 which is 3 ohms
Does this mean I have a dud injector?
Old Oct 28, 2003 | 09:35 PM
69vetteracer's Avatar
69vetteracer
When did you last refuel. Bad gas maybe? :chevy
Old Oct 28, 2003 | 09:38 PM
timallard's Avatar
timallard
Default Re: Engine running rough (69vetteracer)
It started doing it before I refuelled. Tank was pretty low but not on reserve so I don't think I have picked up dirt from the tank.
GiDvEtTe84's Avatar
GiDvEtTe84
Check all sensors! The coolant temp sensor is natorius (sp?) for causing this. Also check TPS and MAF.
Old Oct 28, 2003 | 09:43 PM
timallard's Avatar
timallard
Default Re: Engine running rough (GiDvEtTe84)
TPS is good
Coolant temp sensor is good
I am not sure how to check MAF sensor though
Old Oct 28, 2003 | 09:48 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
The injector reading 3 ohms is bad.
Old Oct 28, 2003 | 09:52 PM
timallard's Avatar
timallard
Default Re: Engine running rough (VetNutJim)
I was afraid someone would say that.
Does the plenum have to come off to get at the injectors?
I wanted to race the car on Sunday. I don't know if I will have enough time to pull it apart and put it back together by then.
Old Oct 28, 2003 | 09:54 PM
vetteguy216's Avatar
vetteguy216
How do you guys check the Ohms on the injectors? If you dont have stock injectors what should the ohms be?
Old Oct 28, 2003 | 10:09 PM
Sam Lam's Avatar
Sam Lam
Default Re: Engine running rough (vetteguy216)
Here is what I know about the injectors in a 89 model! Rochester made an injector called Multec and these have a 100% failure rate due to gasoline shorting out the injector coils. These were used in 89 to 91 L98 engines. If you have a reading like "3" ohms, she is shorted and that one is not working! These injectors cannot be reworked and you will not like the cost of new ones! Find some used ones and send them out for cleaning. I will give you a good source for this if you are interested.
Old Oct 28, 2003 | 10:11 PM
Sam Lam's Avatar
Sam Lam
To check the injectors, remove the connector and place a digitial ohm meter on both connections of the injector. The 89 - 91 injectors should read about 16 ohms. This is an easy and quick check!
Old Oct 29, 2003 | 08:32 AM
Unriced's Avatar
Unriced
Default Re: Engine running rough (oldace84)
Haiku?
_______
Quote:
_______
tony
Old Oct 29, 2003 | 09:01 AM
ittlfly's Avatar
ittlfly
Default Re: Engine running rough (Unriced)
You might send Rich some email ...rich@cruzinperformance.com..........h e has reconditioned my injectors (and a lot of forum members) too. He will probably have a replacment for you at a good price. He will also take the time to answer any questions. A real good guy. :yesnod:
Old Oct 29, 2003 | 09:18 AM
dlmeyers's Avatar
dlmeyers
Hello there,
The 3 Ohm reading suggests a problem.
Run the car, take a long screw driver, place the screw driver on the injector and "listen" to the screwdriver. Best to do this when no one can see you. I like to use a mechanics stethescope.(spelling). The injector "clicking" should be noticeable. Intermittant or no noise is not good. You can also feel the injector moving but tests like this will disclose a failed injector. Intermittant or dirty ones are more problematic.
You could do a leak down test. Place a fuel pressure gauge on the rail, turn ignition on for about 3-4 seconds, note pressure. Turn key off. Should take several minutes to leak down.
OTC, Kent Moore, and others make an injector pulse tester. You hook this up to the injector, use a fuel pressure gauge, turn the key on, pause, then key off, and activate the injector tester. This will pulse the injector a set number of times. OTC can pulse the injector something like 1, 50, or 500 times, depending on setting. If you compare the suspected bad injector with a suspected good injector, the decrease in pressure noted on the gauge is written down and compared. This is the injector balance test on the vehicle. Bench checks are similar but much more accurate.
Your Ohm reading certainly suggests a bad injector.
Good luck with this repair.
dlmeyers 90 coupe zf6 3 speed shocks
To Engine running rough
