What is this?
Old Oct 29, 2003 | 04:47 PM
TuffShift's Avatar
TuffShift
Default What is this?
What is the sensor-looking gadget mounted on the lower passenger side of the timing cover? Mine is beginning to leak oil. Is there a simple way of getting to this thing without disassembling half of the front end?
Old Oct 29, 2003 | 04:50 PM
GRX's Avatar
GRX
Default Re: What is this? (TuffShift)
Did you post a pic? ...because it didn't show....
Old Oct 29, 2003 | 05:16 PM
TuffShift's Avatar
TuffShift
Default Re: What is this? (GRX)
Surely you jest (just kidding). No, I didn't post a pic. I had to literally stand on my head with a mirror and flashlight just to see the damned thing.\
It appears to be right above the front crossmember. And it appears as if this crossmember unbolts? It's only a drip everynow and then leak at the moment. I just don't want it to be getting worse and am checking if there is any way to get too it now, with a whole lot of hassle.
Does the center section of the cross member come out? I may simply be blowing smoke out my **** too, thinking it unbolts; but that is what it looked like.....there wasn't a whole lot of wiggle room beneath the vette at the time I was checking where the oil was dripping from.
Anyone ever had to deal with this before? I could certainly use some tips.
Old Oct 29, 2003 | 06:44 PM
TuffShift's Avatar
TuffShift
Gee, I didn't think the question was that tough. This IS the tech section isn't it?
I tried looking this up in the Haynes service book. It doesn't even tell me what the damned tbing is, let alone how to get to it.
Surely someone has had their motor out and seen this thing. Maybe I'm not holding my mouth right or something?
Old Oct 29, 2003 | 07:48 PM
CFI-EFI's Avatar
CFI-EFI
There is nothing that fits than description on MY engine. Is it really on the timing cover? Does it have wires running from it? If so, where do they go? So far, *I'M* stumped.
RACE ON!!!
Old Oct 29, 2003 | 08:26 PM
69vetteracer's Avatar
69vetteracer
Crankshaft position sensor. You can reach it from underneath. GM has just the O ring for it. :chevy
Old Oct 29, 2003 | 08:44 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: What is this? (69vetteracer)
What YEAR is this thing? Nothing like that on the old Crossfire!
Old Oct 29, 2003 | 08:51 PM
69vetteracer
Default Re: What is this? (CFI-EFI)
95/96. I don't remember if it goes all the way back to 92. Developed for DIS systems. Incorporated into other years and models to improve ignition timing. :chevy
Old Oct 29, 2003 | 09:01 PM
CFI-EFI's Avatar
CFI-EFI
If you are right about his years, thanks. He could have said something.
RACE ON!!!
[Modified by CFI-EFI, 7:04 PM 10/29/2003]
TuffShift's Avatar
TuffShift
It's a '96 LT1. I can just barely see it even with the mirror. It is below the Opti and above the lip of the oil pan, closer to the oil pan, on the passenger side of the front of the motor. I am not 100% certain it is on the timing cover itself. It might be on the block, but it is right down almost to the oil pan.
I can't really see any wire harness attached (but that doesn't mean that there isn't one). There does appear to be a small (about 8 or 9mm) hex-head nut on the end of it, but I can't reach it with a boxend wrench.
Sorry for the 'tude earlier.....this thing just has me frustrated and I'd like to get it fixed before the nasty cold weather moves in.
Old Oct 29, 2003 | 09:10 PM
CFI-EFI's Avatar
CFI-EFI
It's a '96 LT1.
I would have never opened my pie hole if I had any INKLING we were talking about an LT engine.
THANKS !!!
[Modified by CFI-EFI, 7:14 PM 10/29/2003]
Old Oct 29, 2003 | 09:35 PM
69vetteracer
No big deal. Owning a Corvette shop, I see all the crap. It is located in the timing cover. Use a 10mm wrench to get the retaining bolt off and it will pull out. Change the o ring, reinstall and your on your way. I always do it from the bottom but I think you can get it from the top if you unplug the spark plug wires. Have fun... :chevy
Old Oct 29, 2003 | 10:20 PM
TuffShift's Avatar
TuffShift
Thanks VetteRacer, I really appreciate the info.
To What is this?
