Digital board for speedo on '88 model
Old Oct 29, 2003 | 08:48 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Digital board for speedo on '88 model
Tonight I almost got dad's car back on the road. Once we fired it up, I noticed the lighting was not lit behind the cluster. I tapped on the bezel around the cluster and it lit back up. After talking to someone more knowledgeable about those gauge clusters, I was told that the board was probably on it's way out.
Anyone have this problem? If so, how much is the part? Can you get it rebuilt?
TIA
Mark
Old Oct 29, 2003 | 09:35 PM
apollo30346's Avatar
apollo30346
Default Re: Digital board for speedo on '88 model (C4 Newbie)
I to had this same problem and it turned out to be a bad ground in the board.....it did take a little bit to find, but never the less....I did....There are many things it could be...it could just be the cable connections......Try removing the cable from the whole cluster itself and cleaning it.....also try cleaning the plug connections ....there are a few options....Don't spend hard earned money on something you don't need to gett until you have tried all avenues....And yes they can be redone...Mad Direct, Ecklers and such....I think it's an exchange thing....I have taken my cluster apart many times...it's easy...so don't be scared about doing it....it's no big deal...
Hope this helps
Old Oct 29, 2003 | 09:39 PM
69vetteracer's Avatar
69vetteracer
Usually the ground pin from one board to another. Gets some corrosion on them and they start to become intermittant. Clean them up.. :chevy
Old Oct 29, 2003 | 11:59 PM
JAKE's Avatar
JAKE
Default Re: Digital board for speedo on '88 model (69vetteracer)
There's another fix of just soldering a wire on the board to correct the ground problem. Let me see if I can find the link.
Jake
Old Oct 30, 2003 | 12:14 AM
JAKE's Avatar
JAKE
Default Re: Digital board for speedo on '88 model (JAKE)
I couldn't (again) get the link to come up but I can email you the files that has the instructions and photos on how to solder in the ground wire.
Let me know if you want them.
Jake
Old Oct 30, 2003 | 12:32 AM
88_vette's Avatar
88_vette
It's most likely your light bulb not making good contact. You have 4 light bulbs behind that dash if it were not for these you wouldn't see a thing. If you do take this thing apart be very carefull.
Old Oct 30, 2003 | 06:10 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Jake,
If you come across the link, that would be great. I tried a search but to no avail.
It's not a big deal, I'm sure I can take it out and find it, just would hate to go through the trouble of taking it all apart and find out that I missed something.
Mark
Old Oct 30, 2003 | 05:29 PM
brookman's Avatar
brookman
http://batee.com/corvette/
Old Oct 30, 2003 | 05:32 PM
cdnguyred88's Avatar
cdnguyred88
Default Re: Digital board for speedo on '88 model (88_vette)
:iagree:
This happened to me. Change all the bulbs so you don't have to take the Dash apart again.
To Digital board for speedo on '88 model
