Fuel Pressure Gauge
Old Oct 30, 2003 | 10:06 AM
VQT88Vette's Avatar
VQT88Vette
Default Fuel Pressure Gauge
1988 Corvette
I have a cylinder compression gauge. Does it work for checking the fuel pressure? Does the auto parts sell the connection from the comppression gauge to the fuel rail valve?
If it doesn't work, where can I buy one so I can start checking my AFPR.
Thanks,
Old Oct 30, 2003 | 10:51 AM
George West's Avatar
George West
Default Re: Fuel Pressure Gauge (VQT88Vette)
"I have a cylinder compression gauge. Does it work for checking the fuel pressure?"
No - insuffient resolution.
"If it doesn't work, where can I buy one so I can start checking my AFPR."
A fuel pressure gauge will not check air/fuel ratio. But Auto Barn has then for under $30.
George
Old Oct 30, 2003 | 11:27 AM
VQT88Vette's Avatar
VQT88Vette
Default Re: Fuel Pressure Gauge (George West)
[QUOTEA fuel pressure gauge will not check air/fuel ratio. But Auto Barn has then for under $30.
George
[/QUOTE]
I understand that, I just need a pressure gauge to check the base fuel pressure with the OEM FPR before I install the AFPR. This way I know how many PSI I should start out with...
Would the part spell out fuel pressure gauge at the part store?
Thanks,
Old Oct 30, 2003 | 06:17 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: A fuel pressure guage is just that! Autozone has them for under $ 40 and they will say FUEL PRESSURE
Make sure you get a TPI fitting one, not a TBI
Jack
Old Oct 31, 2003 | 09:58 AM
dlmeyers's Avatar
dlmeyers
Default Re: Fuel Pressure Gauge (jackdaroofer)
The ones from Sears should have the "button" style pressure relief valve. This will help if doing a fuel flow test.
Around $40.
I believe Actron makes em.
dlmeyers 90 coupe zf6 3 speed shocks
[Modified by dlmeyers, 8:59 AM 10/31/2003]
To Fuel Pressure Gauge
