I got a pile of engine codes...
Old Oct 30, 2003 | 11:22 AM
Corvettaholic's Avatar
Corvettaholic
Default I got a pile of engine codes...
Alright, in my previous thread I was screwing with the TPS, but since I had it in diagnostic mode, I figured I may as well see what codes show up. Got my initial code 12, so everything is cool, then I got these and I don't know what any of them mean: 22,32,34,42,43,44,54
When I check the codes, is that the same as clearing them, or what else do I need to do to clear my code history? Cause I haven't touched that port in forever, and my SES light loves to keep my company at random.
Old Oct 30, 2003 | 11:26 AM
scorp508's Avatar
scorp508
Default Re: I got a pile of engine codes... (Corvettaholic)
Do yourself a favor. Disconnect your battery for 1 minute and then start the car. See what ones come back after a 10 mile drive.
Old Oct 30, 2003 | 11:44 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
follow scorp's suggestion:
The codes are:
22 - TPS low
32 - Exhause Gas Recirculation Circuit
34 - MAF Circuit (85-90)
42 - EST Circuit
43 - Kock Sensor Circuit
44 - Lean Exhaust Present
54 - Fuel Pump Circuit (low voltage)
Old Oct 30, 2003 | 12:53 PM
Corvettaholic
Default Re: I got a pile of engine codes... (vinnies87)
I apprecitate the codes, I'll follow scorp's idea right after lunch today. Then I'll pull the codes again, I know there will be some, and see what I got then. Thanks guys!
Old Oct 30, 2003 | 01:10 PM
96GS#007's Avatar
96GS#007
Given so many different sensors are affected (did all these codes just show up at once?), it's probably a bad ground.
Old Oct 30, 2003 | 01:46 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Default Re: I got a pile of engine codes... (96GS#007)
I agree with 96GS#007. It is probably due to a bad ground or an ECM/PCM going bad. I'd follow scorp's advice and see what comes back after clearing the codes. If you continue to see muliple non-related codes, check all main grounds and all wiring going to the ECM. Also check the voltage level output of the alternator.
I had a similar problem with multiple non-related codes and replacing the ECM with a NAPA rebuilt unit $117 resolved the problem.
Old Oct 30, 2003 | 02:48 PM
Corvettaholic
Default Re: I got a pile of engine codes... (Mike_88Z51)
How do I check my ground? Where is it at, and whats the best way to get to it? And also equally important, if its all corroded or frayed, whats the best way to fix it?
Old Oct 30, 2003 | 03:18 PM
CFI-EFI's Avatar
CFI-EFI
I doubt they all showed up at once. He just asked how to clear code. This could be a 10 year history. Although he doesn't say how old the car is. Some of these codes could have been set while doing replacements or adjustments.
RACE ON!!!
Old Oct 30, 2003 | 11:08 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: I got a pile of engine codes... (CFI-EFI)
On an 85 the sensor grounds are on the rear bolt of the thermostat housing. They can cause all kinds of odd and random codes.
Old Oct 31, 2003 | 11:02 AM
ninetyfivevette's Avatar
ninetyfivevette
Default Re: I got a pile of engine codes... (LaVidaLoca)
You might want to check you coil and plug wires. I had a similar situation when my coil wire was loose and it was arcing to the engine.
To I got a pile of engine codes...
