only getting 80% throttle.... please help!
Old Oct 31, 2003 | 06:34 AM
SonnyinVA's Avatar
SonnyinVA
Default only getting 80% throttle.... please help!
just installed new engine with new AS&M monoblade throttle body. throttle is only opening 80% according to autotap when using the accelerator, but when i push it open by hand it reads 99.8%. i already adjusted the throttle cable as much as possible in order to allow the throttle blades to close properly, and i also had to open the throttle cable bracket mounting holes to allow for a little more ajustment range.
i don't know how to adjust it any different than what i already did... it looks like the cam on the side of the throttle body can be taken off and rotated but i don't see how that would help.
any ideas or suggestions? my car is a 96 manual trans and is equipped with the ASR (traction control).
BTW, my TPS is reading .58V at idle and the WOT is 3.4V... so that was my first clue that something was wrong. when manually opened to WOT it reads 4.5V.
:confused: :confused:
Old Oct 31, 2003 | 08:52 AM
ittlfly's Avatar
ittlfly
Default Re: only getting 80% throttle.... please help! (SonnyinVA)
A stupid question....have you checked to be sure you are getting full pedal travel ? Nothing under neath to prohibit movement ? Short of that, it has to be the accelerator cable adjustment.
Old Oct 31, 2003 | 09:01 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: only getting 80% throttle.... please help! (ittlfly)
You can adjust the throttle cable? I made a spacer out on the plenum to take up slack...is there a way to adjust it on these cars? :cheers:
You can see the spacer in the picture in my sig, when it comes to the completed picture :cheers:
[Modified by ski_dwn_it, 9:02 AM 10/31/2003]
Old Oct 31, 2003 | 09:12 AM
chucks88's Avatar
chucks88
Default Re: only getting 80% throttle.... please help! (ski_dwn_it)
I had this problem too. What I did was I removed the black bracket on the drivers side of the plenum that holds the TV, cruise and throttle cable. I then dremeled the three mounting holes to slots so that I can slide the bracket front/back and adjusted it acordingly.
Old Oct 31, 2003 | 10:52 AM
SonnyinVA's Avatar
SonnyinVA
Default Re: only getting 80% throttle.... please help! (chucks88)
i tried that already, and it helped get the throttle blades closed, but now i am not getting it opened all the way.
Old Oct 31, 2003 | 10:53 AM
scorp508's Avatar
scorp508
Have you verified by watching the blades open that they are only open 80%? Have someone stand on the throttle and watch the blades yourself.
Old Oct 31, 2003 | 12:46 PM
SonnyinVA's Avatar
SonnyinVA
Default Re: only getting 80% throttle.... please help! (scorp508)
yeah, that was the first thing i tried scorp...
Old Oct 31, 2003 | 02:28 PM
ittlfly's Avatar
ittlfly
I see now that your car is a stick. I should have looked closer. On the LT-1 autos there is an adjustment on the cable from the ASR box to the throttle body.
Old Oct 31, 2003 | 02:38 PM
SonnyinVA's Avatar
SonnyinVA
yeah, i had to adjust it there already just to give it enough slack to allow it to idle.
it does not have any more adjusment available there...
Old Oct 31, 2003 | 05:01 PM
ittlfly's Avatar
ittlfly
If you have already adjusted at that point, there is a procedure to adjust the cams in the ASR box. That is a little more complicated. refer to your Helms as it is somewhat involved.
Old Oct 31, 2003 | 08:12 PM
George West's Avatar
George West
Double up on the throttle valve gaskets?
George
To only getting 80% throttle.... please help!
