94 6 spd grinds into 3rd gear - please help
Old Nov 1, 2003 | 10:06 PM
AEmedic's Avatar
AEmedic
Default 94 6 spd grinds into 3rd gear - please help
My 6 spd grinds into 3rd gear almost every time. If I shift real slow and let the RPMs fall between 2nd and 3rd then it does not grind but if you are going through the gears with any sort of purpose it grinds.
Does anyone know of a cure or even the cause for this?
Old Nov 2, 2003 | 12:23 AM
88_vette's Avatar
88_vette
Default Re: 94 6 spd grinds into 3rd gear - please help (AEmedic)
rebuild. Sounds like syncros (spelling?) Not uncommon with German tranny's from my personal experience
Old Nov 2, 2003 | 01:08 AM
jfb's Avatar
jfb
Worn 3rd gear synchronizer ring.
Old Nov 2, 2003 | 01:17 AM
AEmedic's Avatar
AEmedic
Default Re: 94 6 spd grinds into 3rd gear - please help (jfb)
This sounds like a bad thing.... I don't suppose the home mechanic can do the rebuild?? The tranny sat since 1999, is there a chance that a fluid change could resolve some of the problems I am having?
Old Nov 2, 2003 | 07:22 AM
larryfs's Avatar
larryfs
the fluid change will definately help. it won't solve the problem, but will make shifting easier. for a while at least... until you feel like yanking the tranny out.
Old Nov 2, 2003 | 07:27 AM
bstirn's Avatar
bstirn
Synchronizers allow it to go in and out of gear easily
Old Nov 2, 2003 | 08:17 AM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
You need to describe the symptoms and history to THE expert on the ZF's - Bill Boudreau. Reach him at billb@ZFDOC.COM or stop by his site http://www.zfdoc.com for lots of FAQs.
If your ZF does need repair, Bill's just the guru you'll need.
BTW, a quote from his site:
To date we have rebuilt 152 ZF S6-40 transmissions. I would say that 94% of those units were primarily damaged while operating with some type of degraded hydraulic clutch condition.
[Modified by GS Ragtop, 8:25 AM 11/2/2003]
Old Nov 2, 2003 | 08:56 AM
ffvetteman's Avatar
ffvetteman
One thing you may want to try is a fluid change.
I have a 84 with a Richmond 6 speed and I was getting a grind EVERY time I shifted into 2nd gear. My friend sugested use GM SYNCROMSH Fluid. I tried it and it has not grinded (grammer?) since.
The fluid is about $9-10 bucks a quart, but it saved me from rebuilding my trans. You can get the fluid at a dealership.
Good Luck and let us know what you do.
:steering:
Old Nov 2, 2003 | 11:57 AM
AEmedic's Avatar
AEmedic
Default Re: 94 6 spd grinds into 3rd gear - please help (ffvetteman)
This is what I was hoping, I am going to change the fluid and see what happens.
I am fairly certain that the engine and tranny sat out at the salvage yard rather than in a car for awhile prior to it ending up in my vette.
I have been putting this car back together for over a year and just got it into 3rd gear for the first time yesterday.
Can you lose fluid taking it out or putting it in the car? If so it could be low on fluid and I will find that out too
Old Nov 2, 2003 | 03:22 PM
JasonL's Avatar
JasonL
I seem to remember ZFDoc mentioning that when the clutch hydrualics fail, the 3rd gear synchro is often the first one to go. In your case the damage is already done, but I'd make sure you check the clutch hydraulics are up to par so it doesn't happen again after a rebuild. GOod luck :cheers:
Old Nov 2, 2003 | 03:32 PM
Skippy Stone's Avatar
Skippy Stone
My 3rd synchro has always been bad. I bought it in 92 with 32K on it. I figured either the previous owner was a jerk, or potential buyers had missed some torgue shifts. I now have 89k on that synchro and it's the same has the day I bought it.
Old Nov 2, 2003 | 05:03 PM
bogus's Avatar
bogus
Default Re: 94 6 spd grinds into 3rd gear - please help (Skippy Stone)
when you replace the fluid, use the BMW factory fill, 10w-60 Castrol TWS.
This transmission is NOT a DIY project... these are complex transmissions...
Old Nov 2, 2003 | 05:24 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Add another vote for the fluid change.
My 90 with 125k on the clock used to really have a hard time with third gear and sometimes 4th. I changed fluid to GM and it improved a bit but not enough to make me feel better.
I switched to the BMW stuff and WOW. There is still a little stiffness in the shifting but it is almost not noticable. I am impressed that just a simple fluid change made a world of difference but I am a believer.
Old Nov 2, 2003 | 05:30 PM
AEmedic's Avatar
AEmedic
Default Re: 94 6 spd grinds into 3rd gear - please help (JasonL)
Although I don't think the damage is due to the present setup I can say that my clutch hydraulics had to flushed a good deal to get it to work, like I said it sat for along time, but once I bled it well it did not have a problem, at least all the gears except 3rd are fine...
Old Nov 2, 2003 | 05:31 PM
AEmedic's Avatar
AEmedic
Skippy,
What are the symptoms that you experience? does it grind like mine does?
Old Nov 2, 2003 | 05:34 PM
AEmedic's Avatar
AEmedic
Default Re: (Professor)
Thanks Professor! I like all the good news I can get!
Does anyone know anything about Redline MTL I keep reading that ZF Doc recomends it as well and it is totally synthetic so maybe it won't break down as much as the Castrol
Any Opinions?
Chris
Old Nov 2, 2003 | 07:43 PM
Bans25's Avatar
Bans25
Default Re: (AEmedic)
Any Opinions?
Chris
I thought the ZFdoc recommends the GM, or the fully synthetic castrol?
I didn't think Redline was mentioned on his web site?
To 94 6 spd grinds into 3rd gear - please help
Old Nov 2, 2003 | 08:45 PM
AEmedic's Avatar
AEmedic
Default Re: (Bans25)
I read a number of archived posts that mention him endorsing the Redline MTL as well as the GM and Castrol. I did not get that info off of his site however.
[Modified by AEmedic, 5:46 PM 11/2/2003]
Old Nov 3, 2003 | 08:50 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
To date, the Castrol and the GM fluid are the only ones around endorsed by the manufacturer. There are a few forum members using the Redline with no problems. ZF also recommends Auto tranny fluid (that meets their specs) but I don't think anyone is using it.
Old Nov 3, 2003 | 04:49 PM
Atok's Avatar
Atok
Any Opinions?
Chris
The last time I checked the ZF web page (and ZF Doc's page) they recommend either the Castrol (BMW) 10w60 or GM 5w30 oils, no other. Both these oils are 100% synthetic. ZF also recommends changing the oil on a regular basis...30,000 miles I think (check their web page).
I recently switched to the Castrol stuff and noticed no difference in my tranny. Mine's working fine right now (no grinding), just a weird "two-step" notchy feeling in 3rd (and sometimes other gears) that's been there for some time now. Anyone else have this?
:cheers:
[Modified by Atok, 5:50 PM 11/3/2003]
