question about pistons
Old Nov 3, 2003 | 04:54 PM
Corvettaholic's Avatar
Corvettaholic
Default question about pistons
I was browsing through summit, and I found some SpeedPro forged pistons. Says that with my 64cc combustion chamber trickflows, it should come out a 10.76:1 compression ratio. Anyone know if these things are any good? And what effect would this higher compression ratio have if I decided to use nitrous?
Old Nov 3, 2003 | 07:02 PM
MrSpeedyBob's Avatar
MrSpeedyBob
Default Re: question about pistons (Corvettaholic)
You may not actually get a higher compression ratio. Chiltons lists stock ratio as 10.5, add some carbon deposites and you get to 11 pretty easily
Old Nov 3, 2003 | 07:34 PM
JackDidley's Avatar
JackDidley
I would expect Speed Pros to be good parts. They sell what used to be TRW. Did you see the Trick Flow pistons with a dome matched to your heads? :auto:
To question about pistons
