Calculating injector size.
Old Nov 3, 2003 | 08:44 PM
Hammer's Avatar
Hammer
Default Calculating injector size.
Is there a formula to calculate injector size?
The 383 is going in and I haven't even thought about the injectors.
Jim
Old Nov 3, 2003 | 09:39 PM
Switch's Avatar
Switch
Default Re: Calculating injector size. (Hammer)
If you know what your about what horsepower you can expect with your combo then use the following link:
It should get you in the ballpark. Also keep in mind possible future upgrades.
http://www.witchhunter.com/injectorcalc1.htm
Gordon
[Modified by Switch, 6:42 PM 11/3/2003]
Old Nov 4, 2003 | 08:20 AM
superlund's Avatar
superlund
Here's another real good calculator...
http://www.rceng.com/technical.htm
Old Nov 4, 2003 | 08:59 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Calculating injector size. (superlund)
I would base it on other proven setups. Too large of injectors are more of a hinderance than an advantage.
Guys like beachbum, Cork, and I are all running extremely well with 24# svo injectors. Can't see why you would need more than them.
:cheers:
Old Nov 4, 2003 | 09:34 AM
Hammer's Avatar
Hammer
Default Re: Calculating injector size. (ski_dwn_it)
Why size are the stock injectors in an LT1 motor?
Should injectors be flow matched, or is it overkill?
Jim
Old Nov 4, 2003 | 09:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe the LT-1 uses 24lb/hr injectors rated at ~44psi.
Flow matching injectors is part of blue-printing your engine, much akin to flow matching the ports when porting heads. Though not "necessary" it certainly isn't over kill.
Old Nov 4, 2003 | 11:18 AM
Skippy Stone's Avatar
Skippy Stone
Well according to the calculator below, it would take 33 lb injectors at 42 lbs of pressure for just 425 hp. on a V8. That's interesting.
Old Nov 4, 2003 | 09:10 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Calculating injector size. (Skippy Stone)
too bad the calculators are dead wrong :cheers:
Old Nov 4, 2003 | 09:35 PM
Skippy Stone
Default Re: Calculating injector size. (CORKVETTE1)
That's what I noticed. 8 - 33lb injectors at 42 lbs - that's turbo fuel. :smash:
Old Nov 4, 2003 | 11:39 PM
Switch's Avatar
Switch
Most of the calculators are using 15 or 20% as max duty cycle. With most injectors, and depending on the rpm's involved can do close to 100%. So one could get aprox 15 or 20% more horsepower out of the calculated values. I've been told that they can hang partway between open and closed at very high duty cycles. My ASNU injector machine doesn't have an infinite range of duty cycles to verify this. I am building a circuit that should be able to see this phenomena if it exisits.
Good luck with the fresh engine.
Gordon
Old Nov 5, 2003 | 01:27 PM
Hammer's Avatar
Hammer
Default Re: Calculating injector size. (Switch)
What duty cycle should be used?
Old Nov 5, 2003 | 06:10 PM
superlund's Avatar
superlund
If you play with the RC Eng Inj calculator I posted the link to above it will reproduce the same size fuel Inj. GM used (28.8 LB/HR) in the 2002, 405 FWHP Z06.
I used the following variables;
405 FWHP
8 Injectors
.50 BSFC
76% Max Duty Cycle
58.4 PSI (Stock Z06 FI Pressure)
The RC Eng calculator comes back with a 28.84 LB/Hr injector. In my mind it can't be too far off base...
FWIW, I run the 28.8 LB/Hr Z06 Inj's in my 363 RWHP / 425 FWHP LT4 and I've seen max duty cycles in the low to mid 90% range. That's with around 12.8 AFR @ WOT
[Modified by superlund, 5:19 PM 11/5/2003]
To Calculating injector size.
