Clutch/flywheel gurus, simple question
Over on the general discussion side, there is a 96 flywheel and clutch package that has never been used for a reasonable price. WILL THE 96 CLUTCH AND FLYWHEEL (DUAL MASS OEM) FIT THE 92 LT1? Are they the same GM part #s? Today must be clutch day on the forum. :yesnod:
Cruise-In I Veteran
Cruise-In II Veteran
Yep. The only difference is if it was an LT4, but it will still work perfectly. The clutch disk for the LT4 is just a little better.
