Sylvania HID or ??????
Old Nov 4, 2003 | 06:40 PM
nx-01's Avatar
nx-01
Default Sylvania HID or ??????
Hello All,
I am thinking about getting the Xenarc® HID X6054 Sealed Beam (Sylvania). It sells for $300.
Has anyone gone done this headlight conversion or know someone that has, if so how do you like it or not and why?
Also, I know there are a few other companies that make HID systems, did anyone install a HID system other from Sylvania? If so, how did you like it or not and why.
Thank you guys and take care...John
Old Nov 4, 2003 | 06:56 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Sylvania HID or ?????? (nx-01)
You might want to try to save some big $...Install Sylvania SILVERSTARS...they are head and shoulders better than conventional for a lot less $$$
Many people here have done it with great results
:seeya
Old Nov 4, 2003 | 07:04 PM
Firedawg's Avatar
Firedawg
Cruising
Default Re: Sylvania HID or ?????? (jackdaroofer)
:seeya
:iagree:
Old Nov 4, 2003 | 07:13 PM
red-y's Avatar
red-y
withstupid: Yes try this first
Old Nov 4, 2003 | 07:18 PM
dizwiz24's Avatar
dizwiz24
Default Re: Sylvania HID or ?????? (Firedawg)
The X6054's are absolute garbage.
The light bulb is a D1R HID which is OEM quality, but the reflector housings were made in taiwan and the bulb is so heavily shielded the beam pattern is like a laser beam with awful peripheral lighting.
I had these on mine and am sending them back.
Sylvania is embarrased by them that is why they are discontinuing them.
Junk Junk Junk Junk.
Also, be aware an automotive lighting engineer tells me if you buy a HID setup you need one that comes with a reflector engineered to the HID bulb.
Except not the Xenarc. Sylvania dropped the ball on it. In fact the same engineer i talked to worked on that program when he was with Xenarc.
IF you buy the kit....buy it for the bulbs because $300 is a good deal for D1R bulbs.
Old Nov 9, 2003 | 12:26 PM
nx-01's Avatar
nx-01
Default Re: Sylvania HID or ?????? (dizwiz24)
Thank you all for the replies.
To Jackdaroofer, Firedawg, Red-Y, I will go with the silverstar but I might go with a different housing (aka light bucket) say from Cibié instead of Hella Vision Plus.
http://lighting.mbz.org/products/products.html
http://personal.tmlp.com/scorp/vette...ts/install.htm
To dizwiz24, good information about the HIDs from Sylvannia. I am suprised that the reflecter was NOT designed to take the D1R bulb. What are you running now for lights?
Thank you again to all and take care...
Old Nov 9, 2003 | 12:32 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree:
Old Nov 10, 2003 | 03:44 PM
efi's Avatar
efi
Default Re: Sylvania HID or ?????? (vinnies87)
Try the silverstars, a friend of mine has them and they are pretty good.
If you really want HID, I woud say, go for it.
I got a Hella HID D2S 5600K kit and BMW bixenon projectors, this was the best thing ever done to my car, after painting it, I run the lights even at day heheh. The only problem is that it took me like 2 months to install them since I had to fit the proyector inside my headlamp, but it's possible.
I can email you pics if you need them.
:cheers:
Old Nov 15, 2003 | 12:02 PM
GRX's Avatar
GRX
Tried the Sylvania HID units last years on my truck (REAL HID) ...they are GARBAGE!!! I sent the back after installing them. The install also involves mounting the ballasts and relays....not a simple seal beam replacement! They are crap.
Old Nov 15, 2003 | 06:24 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
I just picked up the Silverstars today and am going to put them in tonight paid $32 CDN each. I'll let you know what they are like.
Old Nov 16, 2003 | 12:54 PM
-=Iron Mike=-
Default Re: Sylvania HID or ?????? (Irish Mike)
Well, I installed the Silversatrs last night and they are a moajor improvement from what I can tell; in the garage. After I give them a formal road test I'll post more opinions. Back to the u-joints............
-=Iron Mike=-
:banghead:
Old Nov 16, 2003 | 01:16 PM
reallycoolcorvette's Avatar
reallycoolcorvette
are these those bright butt lights that were originallly designed for European cars driving on unlit highways & the marginally lit autobahn?
I cant stand those bright butt lights when they are behind me.
:mad
To Sylvania HID or ??????
