A/C control help
Old Nov 5, 2003 | 01:02 AM
OrthoAggie's Avatar
OrthoAggie
Default A/C control help
can you swap from a regular a/c control unit to an auto a/c control unit by just swapping the controls or are there other controls that are different? thanks
Old Nov 5, 2003 | 07:23 PM
OrthoAggie's Avatar
OrthoAggie
Default Re: A/C control help (deiaggie)
anyone?
Old Nov 6, 2003 | 12:35 PM
SunCr's Avatar
SunCr
No - You need to modify the engine, a/c controls and interior lighting harnesses and add a Programmer, Blower Module, Inside & Outside Temp sensors. The a/c ECM signal is 6 volts rather than 12, so you have to modify the chip and on later years, reprogram for diagnostics which are communicated on a separate serial data line.
To A/C control help
