93-96 Coolant Leak ????
Old Nov 5, 2003 | 11:32 AM
fortworth396's Avatar
fortworth396
Default 93-96 Coolant Leak ????
I noticed a coolant smell while driving, after further discovery I noticed that it continues to leak while vehicle is running, but afterwards, residual just runs off.
At first, after some advice from a fellow corvette guru, I checked the coolant transfer at the rear of the motor, between the 2 cylinder heads, NOPE, dry and not leaking. With vehicle running continued looking, but couldn't see anything, except underneath while running small trickle coming from back of block/front of ZF 6speed. Yikes!!
Any idea of something I might check out??
I Did jack the car up and look, checked knock sensors(2) NOPE, It is coming from the backside of the engine. I don't have a clue!
Thanks :banghead:
[Modified by fortworth396, 11:00 AM 11/5/2003]
Old Nov 5, 2003 | 12:20 PM
crheinish's Avatar
crheinish
Default Re: 93-96 Coolant Leak ???? (fortworth396)
Probably coming from between the block and the head. Get a dye kit from your local auto parts store to verify the leak. :cheers:
Old Nov 5, 2003 | 12:46 PM
Steel Blue 91's Avatar
Steel Blue 91
Sounds like an intake leak. Check at the rear of the intake where it mates to the heads. That's where mine was.
Old Nov 5, 2003 | 12:54 PM
fortworth396
Default Re: 93-96 Coolant Leak ???? (Steel Blue 91)
Not coming from the head gasket or intake gasket.
I am thinking it might be a freeze plug in the back of the block, between the block & flywheel. Completely dry up top, but leaks down below.
That is really the only thing I can imagine now that I know it isn't a head gasket, intake, or coolant transfer tube between heads.
Anyone heard of this happening??
To 93-96 Coolant Leak ????
