Rough idle after warm up
Old Nov 5, 2003 | 02:32 PM
wmm1955's Avatar
wmm1955
Default Rough idle after warm up
I have an 85 coupe that idles fine when it is cold, but as soon as it warms up something changes and it has trouble staying at a constent idle. In fact it tries to die. I think it has something to do with a vacuum leak but I can't find it. Anyone out there have this problem before?
Old Nov 6, 2003 | 10:05 AM
MtlSphere's Avatar
MtlSphere
Default Re: Rough idle after warm up (wmm1955)
Yeah. Exact same problem in my 85. No codes.
I've replaced everything but the MAF and the intake air temp sensor now and still have the hunting idle.
It's killin' me! :nonod:
Old Nov 6, 2003 | 10:26 AM
FD2BLK's Avatar
FD2BLK
Check your O2 sensors output. Jesse had a good post on this a while back, do a search and it will give you a good start on checking the problem. I doubt it is a vacume leak because the car runs fine untill it gets warm. It sounds like a Open loop/Closed loop problem.
Old Nov 7, 2003 | 04:41 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
:lurk:
Old Nov 7, 2003 | 07:48 AM
c4power's Avatar
c4power
Put an ohm meter across each injectors pins when the engine is cold. If they are all within .1 ohms of each other, repeat the same test with the engine hot. It's likley that when the motor is warmed up, one of the injector coils is breaking down. :seeya
To Rough idle after warm up
