no closed loop
Old Nov 5, 2003 | 05:12 PM
Pete89's Avatar
Pete89
Default no closed loop
I am having a problem with the vette.I used the Diacom and get a code 13 and 36.The O2 sensor is steady at 425mv and won't go into closed loop.The O2 sensor is 1 year old.I always get a code 13 when driving on the highway for a few minutes.Has anyone had a similar problem?Thanks for any info
Old Nov 5, 2003 | 05:19 PM
scorp508's Avatar
scorp508
Default Re: no closed loop (Pete89)
Help me out, I forget what 13 and 36 are.
Old Nov 5, 2003 | 05:30 PM
Pete89's Avatar
Pete89
Default Re: no closed loop (scorp508)
Code 13- Oxygen (O2) Sensor - signal stays low ("lean") during warm engine cruise
Code 36- Mass Air Flow (MAF) Sensor - burn off circuit problem
Old Nov 5, 2003 | 07:20 PM
vader86's Avatar
vader86
Replace both MAF relays behind the battery on the firewall. Clear the codes and see what comes back.
Usually if you fix the code nearest to the front of the car, the one downstream will disappear.
Old Nov 5, 2003 | 07:22 PM
scorp508's Avatar
scorp508
Default Re: no closed loop (vader86)
I would unplug your battery for 1 minute first before replacing anything, then drive around and see if they come back.
Old Nov 5, 2003 | 08:20 PM
Pete89's Avatar
Pete89
What are the symptoms of a bad ECM?
Old Nov 5, 2003 | 09:19 PM
vader86's Avatar
vader86
A bad ECM is a last resort fix, only when you eliminate everything else should you consider it the problem.
But these symptoms can be explained by having a bad one, its just that the MAF-related stuff is much more likely to fail.
Old Nov 6, 2003 | 07:13 PM
JAKE's Avatar
JAKE
When I first bought my 86 I did some checking and found that my ignition timing was not advancing. I checked everything and found nothing I could put my finger on.
This was my first forray into the TPI world, so I had a steep learning curve to deal with.
I borrowed a friend's ECM, swapped PROMs and the timing problem went away. I knew then it was the ECM, so I bought a remanufactured one from O'Reilly's and 3 years later it's still going strong. $100.00
I've had my share of MAF problems too. Drivability was awful but the car would start and run. I borrowed a MAF from a buddy's 85, plugged it in and she was back to normal. Bought a MAF off a wrecked Vette from a salvage yard; that was two years ago.
Hope this helps.
Jake
Old Nov 7, 2003 | 03:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed get rid of the MAF problem before attacking the other. If the relays don't fix the issue, try to borrow a MAF for test purposes (the MAF from a 3rd Gen. F-body will fit).
If it was running fine for a while after you installed the headers, replace the O2 sensor. If the problem just started after doing the headers, install a heated O2 sensor.
To no closed loop
