Diagnosing engine problems with Data Master
Old Nov 6, 2003 | 02:26 AM
ninetyfivevette's Avatar
ninetyfivevette
Default Diagnosing engine problems with Data Master
I have been trying to track down some issues with my 95 for the past few days, trouble is I am not really sure what I am looking at!
First, to get a base line, I drove to work on my current calibration from pcmforless and I was running super rich. Right and left long term fuel trims were at 108, however short term was right around 122-128 with a heavy gasoline smell.
So I go back to the hypertech tune I had before this, and the long term trims are back in the 120's, but it barely idles and still smells rich as hell. It does not sound like loping from a larger cam, it just sounds like an engine that wants to die.
I have a feeling something is wrong, but I need to find out what things I should be looking at, like IAC position, MAP, etc... Is there an internet resource that gives good diagnostic or tuning advise?
[Modified by ninetyfivevette, 7:27 AM 11/6/2003]
Old Nov 8, 2003 | 02:16 PM
Skippy Stone's Avatar
Skippy Stone
Default Re: Diagnosing engine problems with Data Master (ninetyfivevette)
Have you checked other hardware? Are you sure this is a chip problem?
Old Nov 13, 2003 | 02:33 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Diagnosing engine problems with Data Master (Skippy Stone)
i'm having a similar problem with my PCMFORLESS chip... I'm not getting alot of support from them either.. I hope these guys come through for me.. :yesnod:
Old Nov 15, 2003 | 09:04 PM
Tyler Townsley's Avatar
Tyler Townsley
Have you checked the injectors for leaking? IE Put a guage on it and see if it holds pressure after turning the car off. Good spark on all cyl? Compression?
Tyler
To Diagnosing engine problems with Data Master
