headlight is stuck wtf
Old Nov 6, 2003 | 08:42 PM
Cory00's Avatar
Cory00
Default headlight is stuck wtf
ok my motor took a crap out on me so i used the little turn thingy and booom headlight is back. well i replaced the light bulb and since i have done that the emergency thing stops where it would start to open. when i plug the motor in you can hear it move a little and then it stops like some thing is holding it up. but im 95 % sure nothing is in the way.
any ideas what this could be.... i need to fix it soon because its only a matter of time till i get stoped for one headlight
thanks for the help
Old Nov 7, 2003 | 02:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: headlight is stuck wtf (Cory00)
If turning the manual **** feels "mushy" and the motor runs but doesn't move the headlight, replace the three nylon bushings inside the motor gear housing.
If the motor hums but doesn't sounds like it's turning and the mechanism isn't binding, service the motor; otherwise repair the cause of binding.
Old Nov 7, 2003 | 04:16 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Sounds like it could be as simple as debris in the gear mesh. Pull it apart and clean out the lube and inspect.
Old Nov 7, 2003 | 09:58 AM
korvette4u's Avatar
korvette4u
lite fix could be here for you !! http://forums.corvetteforum.com/zerothread?id=685990 read this thread....sounds like the relays are failing... :chevy
To headlight is stuck wtf
