Tranny problems.
Old Nov 6, 2003 | 10:05 PM
LEERJ1's Avatar
LEERJ1
Default Tranny problems.
I have been driving lately and no problems. The other day on the freeway as i was getting on, it was having trouble shifting but made the shift. The nexy morning as I was going to work, it decided not to shift out of first at all. reverse is fine park is fine. but drive will not shift from first gear to second or so forth. it wont even shift from 1=>2=>d=>od. first gear is it. does anyone have any ideas. thanks in advance and i hope you are all well. :sad:
Old Nov 7, 2003 | 04:07 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Tranny problems. (LEERJ1)
Check the trans fluid.
If it's brownish, it's most likely your trans is toast.
