EGR Tube Clamp
Old Nov 7, 2003 | 10:04 AM
geezel's Avatar
geezel
Default EGR Tube Clamp
Does anyone know of a better design / aftermarket EGR tube clamp other than the stock "crimp" style clamp? I regularly remove the valve covers on my '86 which requires the removal of the EGR tube. Gettting the clamp on and off is a real pain. Any advise?
Old Nov 7, 2003 | 10:15 AM
boxerdog's Avatar
boxerdog
Default Re: EGR Tube Clamp (geezel)
What I've done is use a hose clamp with a little muffler cement. You have to get the clamp on in such a way that you can get a 5/16 wrench or socket on it but it works for me. Just don't overtighten.
Old Nov 7, 2003 | 12:13 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Theres a better way,If you want to spend the money,get a 89-91 exhaust manifold(USed manifolds go for 50-150 bucks) for that side and it has a higher posited EGR feed pipe coming off it,then it connects the egr feed tube with 2 bolts on it.So youd have to get an exhaust manifold,a later model EGR tube,2 gaskets, and 2 bolts and it would be far easier to remove this style egr.I HATE my 86 clamp style and this is the worst design ever.
(Btw,I have a 1990 manifold Im going to use,it has the taller EGR feed pipe with 2 bolt attachement...got the parts used)
Old Nov 7, 2003 | 03:03 PM
dwestsr's Avatar
dwestsr
Default Re: EGR Tube Clamp (boxerdog)
I have the same concern. I thought I might try modifying the existing clamp by removing (grinding off) the crimped part of the clamp and put it on the joint and secure it by putting a SS worm drive clamp over the original. What you you think?
Old Nov 7, 2003 | 03:06 PM
geezel's Avatar
geezel
Default Re: EGR Tube Clamp (dwestsr)
Maybe worth a try... I bought several stock clamps so I could experiment. I'll try it.
Old Nov 7, 2003 | 03:10 PM
dwestsr's Avatar
dwestsr
Please let me know how it works. I'm about ready to put mine back together and I can't get a replacement clamp easily around here. Dealer has to order . Thanks
Old Nov 7, 2003 | 03:13 PM
geezel's Avatar
geezel
By the way, I bought mine through Eckler's, P/N 27006 for $4.99 each.
To EGR Tube Clamp
