88 4+3 overdrive switch
Old Nov 9, 2003 | 10:15 AM
dano7vette's Avatar
dano7vette
Default 88 4+3 overdrive switch
Anyone ever move the overdrive switch off the shifter to a dash or console position? Seems it would work, mounting the momentary switch on the console allowing to use a cue ball type **** and also eliminating invertant switch actuation.
Old Nov 9, 2003 | 10:36 AM
1Patriot's Avatar
1Patriot
Default Re: 88 4+3 overdrive switch (dano7vette)
No need to move it and cause inconvient operation. Once you brain patterns the action of the switch you won't know it's there untill you need it.
I put 125 K miles on an 88 4+3, Z51 without any problem with the button on the shifter, Very handy location when the need to shift arrives.
