RPM Diff. 3.45 vs. 410
Old Nov 9, 2003 | 05:03 PM
STL94LT1's Avatar
STL94LT1
Default RPM Diff. 3.45 vs. 410
My car with 4.10's is only turning 275 more rpms than my friends stock(?) 3.45's ar 60 mph. The 4.10's are turning 1650 rpms, and the 3.45's are turning 1375 rpms. Does this sound right?
Old Nov 9, 2003 | 05:18 PM
LT4BUD's Avatar
LT4BUD
Default Re: RPM Diff. 3.45 vs. 410 (STL94LT1)
Right on the money!!
I calculate 1643 with the 4.10's vs 1383 with 3.45's
Old Nov 9, 2003 | 05:20 PM
darkredlt1's Avatar
darkredlt1
I used a ratio derived from 3.45 divided by 4.10 and multilied the result by 1650 and got 1388. From your numbers, it sounds right.
[Modified by darkredlt1, 4:21 PM 11/9/2003]
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Do both of you have the same trans?Are you in the same gear? Using your 1:1 ratio's and a 26" tire: 2500 rpm w/ 3.45:1's you have 56mph
2500 rpm w/4.10:1's you have 47mph the 4.10:1's would need 3000 rpm to do 56mph a 500rpm diff. Now that doesn't account for convertor slippage and other variables, but it does state that it takes 500 rpm more with the 4.10:1's.
That's the rpm diff all else being equal. Good Luck!
MPH = rpm x tire dia/ ratio x 336
:thumbs:
STL94LT1's Avatar
STL94LT1
Default Re: RPM Diff. 3.45 vs. 410 (LT4BUD)
Thanks BUD, my memory must be getting bad. Seems like I remember my car running 1100 rpms @ 60 mph, with the stock gears.
Old Nov 9, 2003 | 06:05 PM
Darkness's Avatar
Darkness
Default Re: RPM Diff. 3.45 vs. 410 (JUAN J SANCHEZ)
:thumbs:
He has a ZF6 and it has a .49 6th gear
Old Nov 9, 2003 | 06:24 PM
LT4BUD's Avatar
LT4BUD
Default Re: RPM Diff. 3.45 vs. 410 (Darkness)
ZF6 is 0.50:1 NOT 0.49:1 in 6th gear.
Old Nov 9, 2003 | 06:35 PM
Darkness's Avatar
Darkness
On later tranny's the 6th ratio went to .49
http://www.corvetteactioncenter.com/...6/96specs.html
[Modified by Darkness, 3:37 PM 11/9/2003]
Old Nov 9, 2003 | 06:50 PM
LT4BUD's Avatar
LT4BUD
Very interesting!
Page 7-30 of the 1996 Corvette Service Manual says 0.50:1. I am looking right at it.
BUT
I just scanned a couple of Magazine articles on LT4/Grand Sport and they confirm your 0.49:1.
I have always used the 0.50 since that was in the GM manual but it looks like that is probably incorrect.
Geez o man........never can be sure when your right or wrong, oh I am wrong a lot it seems.... SORRY, & thanks for the feedback..
Old Nov 9, 2003 | 06:54 PM
JUAN J SANCHEZ
A little off the topic but while we are talking 6 speeds, did you guys know that the real good 6 speeds come in Vipers and came in some early 93-94 f-bodies? What I mean by good is that the gear ratio's were all close ratio 1st gear wasn't as low (2.80's) and 5th and 6th gear were/are .87 and .62 respectively. This trans would do wonders for acceleration especially in top speed were your rpms won't drop to far from 4th-5th-6th maintaining good acceleration through out!
To RPM Diff. 3.45 vs. 410
