Anyone do a SD to MAF conversion?
Old Nov 10, 2003 | 01:25 AM
neat's Avatar
neat
Default Anyone do a SD to MAF conversion?
I was wondering if anyone had ever converted a speed density car to MAF? What all was/is involved?
Old Nov 10, 2003 | 08:01 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Anyone do a SD to MAF conversion? (neat)
Yeah lots have done it, but the better question is why have they or why would you want to? :confused: :lurk:
Old Nov 10, 2003 | 08:05 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Anyone do a SD to MAF conversion? (ski_dwn_it)
jess i think you are reading his question backwards :cheers:
Old Nov 10, 2003 | 08:16 AM
Steel Blue 91's Avatar
Steel Blue 91
To the best of my knowledge, 90 and 91 were the only two years for speed density. Your 92 should be a mass air flow car. I'm confused :confused:
Old Nov 10, 2003 | 08:49 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Anyone do a SD to MAF conversion? (CORKVETTE1)
:-D-O-H! Was having my morning coffee at the time....MY BAD :lolg: :leaving:
[Modified by ski_dwn_it, 8:50 AM 11/10/2003]
Old Nov 10, 2003 | 09:13 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Anyone do a SD to MAF conversion? (Steel Blue 91)
Actually Speed Density only was 90-93.
Old Nov 10, 2003 | 09:56 AM
Steel Blue 91
Default Re: Anyone do a SD to MAF conversion? (-=Jeff=-)
Learned something new. thanks, I stand corrected.
Old Nov 10, 2003 | 10:20 AM
mn_vette's Avatar
mn_vette
You should be able to do it with a '94+ computer. You might have to redo some of the pinouts on the wiring harness though. It seems to be more work than it's worrh though. You might as well pay a little more and get an after market standalone then.
Old Nov 11, 2003 | 06:39 AM
93 ragtop's Avatar
93 ragtop
Default Re: Anyone do a SD to MAF conversion? (mn_vette)
You also, will have to work around the problem of the 94 up using the electronic transmission, (4L60E) where as the 93 and down used the 4L60 no E on it or the 700r4. IMHO it aint worth the effort.
Old Nov 11, 2003 | 07:56 AM
ZD1's Avatar
ZD1
Hmm what if your car has 50-60% MAP readings at idle, 30% at cruise, and 102% at WOT? How would you meter the fuel? Granted this is for a TPI, which I no longer have...
To Anyone do a SD to MAF conversion?
