"Lurching" Problem
Old Nov 10, 2003 | 12:19 PM
geezel's Avatar
geezel
Default "Lurching" Problem
I have an '86 with a manual transmission. At low RPM's in 1st gear, in a parking lot for instance, the car tends to "lurch". Sometimes it's quite severe. The only way to stop the lurch is to depress the clutch. It's always done it, before and after some minor mods (cam, rockers, TB, etc). Runs great otherwise. Any ideas?
Old Nov 10, 2003 | 12:26 PM
dwestsr's Avatar
dwestsr
Default Re: "Lurching" Problem (geezel)
That is a typical problem with lopey cams. At low rpm and in gear , the uneven rpm causes the driveline to load and unload. Been there, done that!! :cheers:
Old Nov 10, 2003 | 12:28 PM
geezel's Avatar
geezel
Default Re: "Lurching" Problem (dwestsr)
It did it with the stock cam also.
Old Nov 10, 2003 | 12:34 PM
dwestsr's Avatar
dwestsr
Did the car idle smoothly with the old cam? It it lopey or smooth with the new cam?
Old Nov 10, 2003 | 12:38 PM
geezel's Avatar
geezel
Idled smooth with the stock cam - Idles lopey with the new cam. The new cam is a TPIS Hyd flat tappet 280-280. Thanks for your input.
To "Lurching" Problem
