Pre cats Question
Old Nov 10, 2003 | 10:48 PM
darkred91's Avatar
darkred91
Default Pre cats Question
Will cutting off the pre cats make your car run lean if so whats the cure...THANKS.
91 L98
[Modified by darkred91, 3:49 AM 11/11/2003]
Old Nov 10, 2003 | 11:06 PM
bogus's Avatar
bogus
Default Re: Pre cats Question (darkred91)
I have never heard that... the precats are designed to light off faster, so they can get lower emissions sooner.
Old Nov 11, 2003 | 12:37 AM
TA's Avatar
TA
I replaced my front y-pipe about a year ago with a 2.5" SS unit w/out precats and have had no problems. The only consequence was quicker ETs :yesnod:
Old Nov 11, 2003 | 01:03 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Pre cats Question (TA)
Don't worry about running lean without precats. Your ECM is smart enough to make sure things run as they should with a basic mod like that.
Old Nov 11, 2003 | 01:54 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The ECM will get the A/F correct at part throttle in closed loop; in open loop it should run a little leaner due to more air flow.
People have said that our stock L98 run a little rich at WOT so a little leaner should not matter.
You can use an AFPR to tune fuel flow at WOT for best power using a dyno or trap speed data.
Old Nov 11, 2003 | 02:19 AM
The Dingo's Avatar
The Dingo
Default Re: Pre cats Question (65Z01)
Doh! I overlooked that point about WOT... :bb
To Pre cats Question
