I found some hooker headers for my 84, but I dont know if I should opt for the ceramic coated ones. What do they offer (performance, durability) and is that extra 200 bucks better spent elsewhere? Also, are there any cheaper prices? http://www.speeddemonmotorsports.com...exhaustC4.html
Re: Ceramic headers; Any better? (somethingerother)
Definitely spring for the $$ and get em ceramic coated in/out:
-they flow better==more hp
-they last longer
-they look better
The ceramic coating keeps the heat inside the exhaust gasses which keeps the engine compartment cooler and, most importantly, gives higher exhaust gas velocity resulting in more power.
There's one problem though. Hooker DOES NOT coat their headers on the inside. You can either not worry about that (seems like most people don't), or have them coated by someone like Jet-Hot or HCP, which will cost another $250-$300 (eek).
Inside as well as outside coated are the best way to go, the next best is the standard external coating only. Whatever you do, don't leave them uncoated if you plan on keeping your vette as a daily driver.
One of the main reasons for ceramic coating is to keep the heat INSIDE the header especially if you have UNHEATED O2 sensors which REQUIRE the heat in order for the engine to properly calculate the engines exhaust. If you use uncoated headers the heat may bleed off to fast and not properly heat the O2 sensor and you'll never get into closed loop. Also the other biggy is uncoated headers get nasty looking after some time, ceramic tends to resist changing colors over time from the heat dissipation.
-they last longer
-they look better
I bought the Hooker Shorties directly from Jet-Hot and had their Sterling coating (ceramic) process. I've been running them since last spring and they still look new. Even if it's not Jet-Hot, go with the ceramic coating, unless you enjoy changing your headers every few years.
:nonod: I had mine done by HPC a couple of months ago for $80.00. They did such a nice job, I had them do the inside and outside of the front and rear Y pipes as well.
Thats super! Why so inexpensive vs. Jet-Hot? Does HPC offer the same kind of warranty?
Coating outside tends to resist the elements and minimize corrosion; coating inside keeps the heat in the exhaust gasses.
It's best to locate the O2 sensor as close to the collector as possible; then with ceramic cloating inside you likely won't need to use a heated O2 sensor.
You need a heated sensor with long tube headers? They cool uncoated so much more efficiently than the original stainless short tubes that they cannot heat the sensor enough? The original L98 O2 sensors are not heated, don't know about LT-1's.
Another reason to coat the inside is to protect the header itself if you are really working the engine. The ceramic coating will protect the steel from the excessive heat in the exhaust gases. Stainless steel especially can get brittle and crack from excessive heat.
Since the headers are SO much fun to install in the first place, might as well get them to last as long as possible with as little maintenance as possible.
I didn't realize you asked the same thing, I only saw the answer and since i have never heard of anybody converting to heated sensor(s) because of headers I asked about it. So, guys are saying that you need heated ones. Good to know.
