Cloyes True Timing chain?
Old Nov 11, 2003 | 06:10 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Cloyes True Timing chain?
Installed on my '84. I think it makes more noise. Anyone else seen this.
Performance is good.
A little more sound?
Let me know
thanks
tony
:flag
Old Nov 11, 2003 | 06:19 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Cloyes True Timing chain? (oldace84)
An all steel, double roller, timing set does make more noise than the stock morse chain and nylon timing set. That's the main reason the factory uses that set up. Trucks (at least above 1 ton) use roller chains. Good luck, and...
RACE ON!!!
Old Nov 11, 2003 | 06:57 PM
oldace84's Avatar
oldace84
Default Re: Cloyes True Timing chain? (CFI-EFI)
CFI-EFI,
Thanks for the info.
tony
To Cloyes True Timing chain?
