knowing that your after every ounce of power in that car, I am making the connection with this that your worried about alternator draw to supply the fans with current.
I just wanted to mention what after a certain MPH ~30 the fans are shut off my the ECM, so it shouldn't effect anything to aweful much. Just be aware of the other stand alone coolant sensor that can kick the fans on, that I believe will override the ECMs control.
If your not inquiring about this for power, then carry on. :cheers: :thumbs:
I don't think the 91 has a "stand-alone" fan switch. If I recall correctly, only the ECM can control them.
As I recall the 91 has 2 smaller side by side fans. The 87 has one big fan that is controlled by the ECM. The fans are a DC motor, which means they have a high starting current. I think GM uses a 20 Amp fuse for these circuits. That is enough to get the fan moving and not pop the fuse. After the fans gets moving, these smaller fans should pull in the neighberhood of 10Amps.
as said, once you get some speed you won't need the fans, but don't get stuck in traffic w/o them. i.e. Staging lanes.
Jesse, what alternator? I had a few issues with it and I took it off. My car has the remote charging lugs and I charge the battery that way. The Optima battery that I'am using has a RC of ~90 amps. I would like to use the fans to cool the motor down to 120 between rounds. The fans seem to be a very draining accessory. I control each fan on its own switch. The ecm is no longer controlling my fans.
There is a very good tech article on sizing and calculating the RC values of a battery. Let me know , if anyone is interested and I will post the link.
But let me ask, can't you just cool the car down, while its attached the the chargers? I'm not electrical guru, but perhaps this would cause the battery to not fully charge....NOt sure. :cheers:
Yes, per fan.
It has been a little while since I messed w/ fans, but 10A per fan should be safe.
10A-20A is a heavy draw, when compared to only running an Ign, Fpump, Inj, and ECM. Don't run the battery too low, or the first that will suffer will be the Fpump. Next will be spark. (An MSD will solve this one.) There are many variables here, but these 2 should be your weak points.
At low voltage, your fuel pressure will get lighter, and the inj's will open slower.
You really wanna go hog wild,... if you run heated O2's, disconnect the heater section. That will save you 1A-4A per sensor.
