Time to replace shocks... what to buy?!
Old Nov 13, 2003 | 12:57 PM
jutammel's Avatar
jutammel
Default Time to replace shocks... what to buy?!
Hi all, I have an -88 coupe with 80k miles. It has original Delco Bilstein shocks and I think it's time to change them. I was looking over Corvette Central and MAD cataloques and they had KYB, Bilstein and Edelbrock to choose from. I am at loss with these, which of these is the best for me?? My vette is with Z52 option and I like the firm ride of it. I've heard that KYB might be too soft for me.
Could you please help with these choises :)
Old Nov 13, 2003 | 01:16 PM
Trey96LT1's Avatar
Trey96LT1
Default Re: Time to replace shocks... what to buy?! (jutammel)
its best to replace with what you have on there now which should be Bilsteins
they are over twice the price of KYB but worth it
I just installed KYB on my 96 because I couldnt afford the Bilsteins right now and they are much better than my 94k miles original Bilsteins but if I could afford the new Bilsteins I would....so go with replacement Bilsteins and enjoy the ride :steering:
Old Nov 13, 2003 | 02:07 PM
jutammel's Avatar
jutammel
Default Re: Time to replace shocks... what to buy?! (Trey96LT1)
Hi Trey, I'm leaning towards Bilsteins too. MAD has, for example, base suspension and Z51 suspension bilsteins for sale?! No bilsteins for Z52? Can I choose either one for my Z52?
Old Nov 13, 2003 | 02:12 PM
dmrodco's Avatar
dmrodco
Z52's had bilstiens !!! Mine does ....and VETTE BRAKES and products has them for the Z52
[Modified by dmrodco, 12:13 PM 11/13/2003]
Old Nov 13, 2003 | 06:14 PM
John Row's Avatar
John Row
Just have your existing Bilsteins rebuilt. Bilstein does it for something like $50-$60 each. They'll revalve them to your specs (and help you figure it out) for a bit more.
Old Nov 13, 2003 | 06:38 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Time to replace shocks... what to buy?! (John Row)
:cheers: On my 88, I run with the Z51's front and rear (car is a Z52 rdstr), combo works great!!!
I have upgraded to 30mm solid front sway bars and 24 mm rear, that too is a nice change you might want to consider
:seeya
Old Nov 13, 2003 | 10:07 PM
eddieL98's Avatar
eddieL98
Default Re: Time to replace shocks... what to buy?! (jackdaroofer)
first put away the MAD catalog. they are kind pricey. i have the edelbrock IAS and found them on another site for $70ea bucks. the Bilsteins i think someone founf them on another supporting vendor for $90ea. not sure on the KYB's
I like the edelbrock for my application because the vette is my daily and the roads here in ft worth are pretty hard to drive.
if i had smoth raod on my way to work i might have picked the Bilsteins. i have heard you can send them in to be rebuilt. hope this helps some
Old Nov 13, 2003 | 10:33 PM
89CONV's Avatar
89CONV
Trey96LT1
:iagree:
Old Nov 13, 2003 | 11:23 PM
Corvette0096's Avatar
Corvette0096
KYB :yesnod:
Old Nov 13, 2003 | 11:56 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
:iagree:
Old Nov 14, 2003 | 01:40 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Go to the track and look at what the pros use. Koni is my preference because they build shocks for nearly every form of transportation. Koni knows its business which is why most racers choose Koni. Just wish the darn things were more affordable.
I don't work for Koni :D
Old Nov 14, 2003 | 02:26 AM
Maximus9000's Avatar
Maximus9000
Default Re: Time to replace shocks... what to buy?! (JrRifleCoach)
I think there is someone with a set of four Koni's on the worlds marketplace, cheap! I saw them last night.
Old Nov 14, 2003 | 03:33 AM
JOliver's Avatar
JOliver
Default Re: Time to replace shocks... what to buy?! (Maximus9000)
I'm in the middle of this on my 90..I was gonna go the super cheap route and throw some Monroes(24.99 each) on it ...Went to Advance and bought some,was doing front brakes the other night and pulled my Bilsteins off (they're wore out big time) but they had more dampening than the new Monroes I bought ...I also sqeezed one Monroe in and it didn't come out at all...so they got returned real FAST....I ordered a set of the KYBs from Ecklers..bought all four for 149.00(I think) plus I get a Vendor discount of 20%...I think they are gonna suit my needs just fine.I don't race at all and I like a good ride...not too firm like the bilsteins and not too cushiony like some of the the cheapies.
KYBs in my opinion!
Jason
Old Nov 14, 2003 | 08:10 AM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Default Re: Time to replace shocks... what to buy?! (JOliver)
Bilstein shocks are the only way to go on a Vette. :cheers:
Old Nov 14, 2003 | 08:45 AM
Lone Ranger's Avatar
Lone Ranger
Default Re: Time to replace shocks... what to buy?! (meyre1)
Call me shock dumb but what is it that Bilsteins do that something like the non-Bilstein KYB's don't?
Old Nov 14, 2003 | 09:08 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I have been running KYB's for about 2 years now and I am happy with them. I try to avoid the "Corvette Tax" whenever I can. :D
Old Nov 14, 2003 | 09:53 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Time to replace shocks... what to buy?! (joecaver)
If you are looking for a serious adjustable shock for you Vette, go with HAL QA1 12 way adjustables. You can change both compression and rebound valving simultaneously, just turn the adjustment **** with your hand. No need to remove the shocks to make the adjustment. They are also rebuildable. I can adjust them for a Auto-X or Drag set-up at the track, then adust them for a nice smooth ride home. I can adjust all 4 shocks in under a minute. I've been using them for close to a year...I'd never use anything else on my car. Talk to the other guys on the Forum that use them. :yesnod:
To Time to replace shocks... what to buy?!
Old Nov 14, 2003 | 09:54 AM
jutammel's Avatar
jutammel
Thanks for all replies guys! Doesn't make my desicion any easier thou. Everybody got their own favorite. I might be leaning towards Bilsteins becouse I already have those. So let get this right, I can put base suspension bilsteins and Z51 bilsteins on my car if I want. Only difference is that Z51 bilsteins are harder?
Old Nov 14, 2003 | 10:38 AM
Sport 718's Avatar
Sport 718
Hello, It's Tony from Vette Brakes & Products. I will give a special price today of $ 68.00 on Bilstein Shocks. C-4 and C-5 only. 800-237-9991 or you can e-mail tony@vettebrakes.com.
Sport 718
Tony
Old Nov 14, 2003 | 11:54 AM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Zip has Bilsteins on sale for $269.95. I just bought some last week :thumbs: .
