Worried About Opti-spark
Old Nov 13, 2003 | 08:13 PM
derv3tt3's Avatar
derv3tt3
Default Worried About Opti-spark
When the opti goes bad does it give any error codes?My 94 runs good until I turn it off.Then on start up it wants to back fire and run rough for awhile then it might smooth out.What do you think? I've done a lot to my 78 but not the C4 so not sure if I can change the opti. :confused:
Old Nov 13, 2003 | 10:34 PM
bogus's Avatar
bogus
Default Re: Worried About Opti-spark (derv3tt3)
how many miles?
what kinda maintenance has been done already?
has the engine been water/pressure washed?
Old Nov 14, 2003 | 07:36 AM
Aaron71771's Avatar
Aaron71771
The opti wont throw any codes when it goes bad. Your problem might be something else since the car runs good until you shut if off. Leaky injector maybe?
Old Nov 14, 2003 | 09:02 AM
sraft's Avatar
sraft
What you describe could be attributed to a little bit of moisture in the opti. When it first starts up, the moisture causes some misfiring. As the area heats up, the moisture evaporates the misfire goes away. Your '94 has the non-vented opti, so any moisture will stay in there for a long while. Try putting a shop light (one with an incandescent bulb that makes heat) on the floor under the opti while it's not running. If it starts with no misfire, it's more reason to believe that moisture is indeed the problem.
Old Nov 14, 2003 | 09:45 AM
ittlfly's Avatar
ittlfly
Default Re: Worried About Opti-spark (sraft)
The opti CAN throw a code but not always as mentioned above. Codes 16 & 36 are opti related. They refer to the low and high resolution respectivly (sp). You car will run with the high res. missing (code 36 ) but will not start if the low res. is missing (code 16.)
[Modified by ittlfly, 6:46 AM 11/14/2003]
Old Nov 14, 2003 | 03:11 PM
derv3tt3's Avatar
derv3tt3
Default Re: Worried About Opti-spark (ittlfly)
Car has 23,500 miles on it and nothing has been done to the engine like plugs or wires. :rolleyes:
Old Nov 14, 2003 | 03:17 PM
Lone Ranger's Avatar
Lone Ranger
Only 23K on a '94? Needs some driving. Seriously. These cars hold up better and run better when driven more frequently than sitting around driven infrequently... 'specially LT1's / LT4's. :yesnod:
Old Nov 14, 2003 | 04:03 PM
derv3tt3's Avatar
derv3tt3
Default Re: Worried About Opti-spark (Lone Ranger)
That's what my wife says about driving it more.The longest trip is to Carlisle after that its just around the area.Car starts fine until it warms up then shut off. :rolleyes:
To Worried About Opti-spark
