Shift Kit vs Computor Program for firm shifts
Old Nov 14, 2003 | 08:11 AM
94 Red Roadster's Avatar
94 Red Roadster
Default Shift Kit vs Computor Program for firm shifts
What is the difference between a shift kit and a computor program like Hypertech that gives you firmer shift points? Can either one cause damage to a standard auto transmission?
Old Nov 14, 2003 | 08:58 PM
c4power's Avatar
c4power
Default Re: Shift Kit vs Computor Program for firm shifts (94 Red Roadster)
Hyper chips and the like have an effect on shift points and converter lock up whereas shift kits literally change the oil pressures inside the transmission as well as having an effect on the shift points by the change in pressure. This is acheived by the removal or resizing of "check *****" within the oil galleys and replacment of the springs on the valves inside the valve body wich results in the desired effect. While hard shifting from a shift kit would seem to be harder on a transmission, the reality is that the harder shifts result in less slippage within the clutch packs internally and actually offer less wear. Now.. keep in mind an eprom swap is a 5 min job, a shift kit on the other hand is a nice afternoon on your back. :smash:
Old Nov 15, 2003 | 11:07 AM
honas's Avatar
honas
Totally Agree!!!! :iagree:
To Shift Kit vs Computor Program for firm shifts
