removing my headlight motor
Old Nov 14, 2003 | 11:49 PM
Cory00's Avatar
Cory00
Default removing my headlight motor
this is going to be my weekend project... i want to take apart the headlight and see if i cant spare my one headlight. is it hard to do. is there any site with some good pics to help walk to threw. i have a haynes book but i need more. also what are some good things to clean while i have the headlight out.
any help would be great :cheers: :cheers:
Old Nov 15, 2003 | 12:11 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: removing my headlight motor (Cory00)
Good Luck Cory.
:auto:
Old Nov 15, 2003 | 02:05 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will need a drift to remove the drift pin that holds the motor to the shaft and a long allen wrench would help in removing two of the Tors bolts that hold the assembly to it's frame.
Good luck, it's not a bad project to remove it.
To removing my headlight motor
