Oil Temperature Switch Leak
Old Nov 15, 2003 | 11:44 AM
RJVette23's Avatar
RJVette23
Default Oil Temperature Switch Leak
Help......
I can't seem to stop the leak around the Oil Temp Switch. I've tried teflon tape, RTV, a new switch, etc.:banghead:
Any ideas on how to stop this annoying leak?
Thanks in advance.
RJVETTE23
Old Nov 15, 2003 | 11:53 AM
Corvette0096's Avatar
Corvette0096
Default Re: Oil Temperature Switch Leak (RJVette23)
This the one on back of the block by the distr? I always use Pipe tread seal on everything and never have I once had a leak. Its a liquid Made by Loctite
Old Nov 15, 2003 | 11:56 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Oil Temperature Switch Leak (Corvette0096)
:cool: :thumbs:
Old Nov 15, 2003 | 12:14 PM
JAKE's Avatar
JAKE
Help......
Thanks in advance.
RJVETTE23
Which one are you talking about?
The temp switch which reads out on your digital dash is on the block just above the oil filter.
The ones by the distributor are the oil pressure sender (for dash gauge) and the oil pressure switch (which will energize the fuel pump).
Jake
Old Nov 15, 2003 | 04:28 PM
RJVette23's Avatar
RJVette23
Default Re: Oil Temperature Switch Leak (JAKE)
It's the temp switch just above the oil filter. I'll try the pipe thread loc. Thanks for the help.
RJVETTE23
Old Nov 15, 2003 | 04:53 PM
froggy47's Avatar
froggy47
I've got this too, low on the block, pass side on my lt4. Can you specify which pipe thread sealant. There's a few.
Like plumbers epoxy that you knead together in your hands.
Or some you paint on with a brush.
There's stuff for pvc.
Just want to use the right one. Will it still come off if needed, after?
Sorry, just reread the post. A liquid made by Loctite - just says pipe or plumbing on it?
[Modified by froggy47, 1:55 PM 11/15/2003]
To Oil Temperature Switch Leak
