Air Foil help
Old Nov 15, 2003 | 07:22 PM
Ras119's Avatar
Ras119
Default Air Foil help
I just acquired an air foil for my 1990 coupe. Problem is, is that is doesnt fit snuggly in my throttle body. It came with no screws and or mounting hardware....It will not seem to stay in there when the air filter hose is attached either. I know these things arent worth all that much in the big scheme of things...but i already bought and would like to use it. Any help would be appreciated.
Old Nov 15, 2003 | 07:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Air Foil help (Ras119)
Does the air foil have any screw holes in it?
Who is the mfg?
Old Nov 15, 2003 | 08:36 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Air Foil help (65Z01)
There are two types that I know of.
This is Eckler's Inlet Fairing:
And this is MAD's Flow booster:
Not sure which onw you have. MAD's is the screw in and Eckler's is the type that is held in place by the air duct.
Old Nov 15, 2003 | 09:07 PM
Ras119's Avatar
Ras119
I have the Ecklers model. It seems to hang outside the front of the TB quite a bit further than I imagined. The air duct alone doesnt feel like it will keep it in place...although I may just need to mess with it a bit more.
Old Nov 15, 2003 | 09:57 PM
JB666's Avatar
JB666
I know what your talking about, as mine wouldn't fit into the TB either. After I did some searching, I found that I had gotten the type that sat in the intake, (wedged in, actually) right before the TB. Well, I left it in for a week, and realized what a peice of junk it was, and got rid of it...
Old Nov 15, 2003 | 09:58 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I think these things make great E Bay auction items!
Sell it cheap, but charge a lot for shipping and handling!
You might actually make a profit...which would be the biggest benefit you would get from that thing...IMHO :D
:seeya
Old Nov 15, 2003 | 10:09 PM
Ras119's Avatar
Ras119
Default Re: Air Foil help (jackdaroofer)
maybe I'll send it right back...it just came today. thanks for the input though.... :banghead:
Old Nov 15, 2003 | 10:53 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:D Good Idea! :D
:seeya
To Air Foil help
