rocker arms on L98
Old Nov 16, 2003 | 07:22 AM
corvette90's Avatar
corvette90
Default rocker arms on L98
hi all..
need rocker arm suggestions..
i want to keep the stock centerbolt valve covers
does the L98 have self aligning rockers??
i have guideplates in the cylinder head.. and im a little bit confused
ok, here it is..
i have put in a Comp cams Xtreme energy, upgraded springs, 7.300 pushrods, and now, im searching for rockers..
i found CCA-1417-16
what do you think about?
will they fit under it??
thank you!!
Old Nov 16, 2003 | 10:04 AM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: rocker arms on L98 (corvette90)
I am curious on the answers this will get also,,,,, I am thinking I am going to put some 1.6RR on mine soon, but just dont know enough about it.... :banghead:
Old Nov 16, 2003 | 01:08 PM
chucks88's Avatar
chucks88
I am in the process of freshing up my valve train as I type this. I'm going with ...........
1.6RR Pro Magnums from Comp Cams(self aligning)
new springs
retainers
locks
pushrods.
valve seals
My '88 L98 came with guide plates whose function is more to ease the assembly at Bowling Green than it is to guide the pushrods.
Your stock rocker arms are self aligning.
I bought the self aligning style RR to use on my stock 3/8 studs and I am pulling the stock guide plates. I noticed during my teardown that my pushrods where rubbing up against the guide plates.
If you want to use your stock valve covers, which you can, you'll have to lop off your drip tabs and narrow down the bolt channels.
Old Nov 16, 2003 | 01:41 PM
corvette90's Avatar
corvette90
Default Re: rocker arms on L98 (chucks88)
ok, you mentioned with 1.6RR
i want to go to 1.52 ratio, i hope this doesnt affect power or idle in any way...
do i have to cut the drip tabs also, or can i leave them..??
thank you
Old Nov 16, 2003 | 01:55 PM
corvette90's Avatar
corvette90
ohhh sorry..just seen a fault of myself..
i don´t mean roller rockers, i meant roller TIP rockers...
stamped steel ones with a roller tip...CCA-1417-16
thank you
Old Nov 16, 2003 | 02:03 PM
chucks88's Avatar
chucks88
You might be able to get away 1.5's without hacking up your covers. Do a search about it and I'm sure you'll find something, because I'm not sure.
Old Nov 16, 2003 | 06:32 PM
88_vette's Avatar
88_vette
Comp cam Mag rr 1.52 or 1.6 have the same body the pushrod push point is different that's it. Yes you will have to mod your valve cover for either.
Old Nov 17, 2003 | 03:09 PM
SmokeGray89's Avatar
SmokeGray89
I installed a set of Comp Cams self aligning 3/8 stud 1.6 roller tip rockers #1418-16 on my 89. They are the same heigth as the factory 1.5s so they should fit without any modification to the factory valve covers. If you have factory guide plates (the manual says 90's did not have them) you should also have hardened push rods. I would replace the push rods with a new set to be on the safe side. Dan
Old Nov 17, 2003 | 03:18 PM
MrNuke's Avatar
MrNuke
Default Re: rocker arms on L98 (SmokeGray89)
I've been running 1.52 rr Comp Camp Magnum Rockers for over a year and the fit without any issues.
Old Nov 17, 2003 | 03:36 PM
Flame Red's Avatar
Flame Red
Crowler 1.6 Full Rollers
They will fit under the stocker covers - you have to drimmel off the drip tabs. But I went with a cool set of Billet Specialities covers while I was in there.
Old Nov 17, 2003 | 04:04 PM
corvette90's Avatar
corvette90
Default Re: rocker arms on L98 (Flame Red)
thank you all..
good news for me...so i will order the comp cams 1417-16, since they will fit under my stock covers..
and also new pushrods, stronger ones than factory..
thank you!!!
Old Nov 17, 2003 | 04:14 PM
scorp508's Avatar
scorp508
I see the 1417-16 being for a 4.3L engine. I think you'd want 1412-16 for your 350.
Are you dead set on 1.52s? I don't know how much improvement you'll see going with only a rollertip rocker in 1.52 ratio. Modifying the stock valve covers isn't too hard.
If cost is an issue then stick with the 1412-16. If it isn't then you may want to consider....
1301-16: 1.52 pro magnum, full roller, $265
1302-16: 1.60 pro magnum, full roller, $265
Old Nov 17, 2003 | 04:22 PM
C10 JDR's Avatar
C10 JDR
Default Re: rocker arms on L98 (scorp508)
Proform do a full roller set for about $180 I think) I got mine from Summit.
Old Nov 18, 2003 | 02:56 AM
corvette90's Avatar
corvette90
hi..
@ scorp508...hmm..what i ve seen the CCA 1417-16 will fit Chevrolet 265-400cui, with centerbolt valve covers, self-aligning...says online catalog at compcams.com, also says at summit
i think, the 1412-16 are the same, but not self aligning....
i want to go with 1.52, since i will run a cam with higher lift, and dont want to get clearance troubles, or such things...
thank you anyways...
Old Nov 18, 2003 | 05:27 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Re: rocker arms on L98 (MrNuke)
I had heard that the early vette perimiter valve covers can fit the 1.6RRs no problem...its the centerbolts that have problems...
Thank might clear up some confusion! :thumbs:
Edit: Just saw you posted at the same time that you ordered ones that said they would fit centerbolts...Have fun! :thumbs:
[Modified by USAsOnlyWay, 4:29 AM 11/18/2003]
Old Nov 18, 2003 | 09:57 AM
scorp508's Avatar
scorp508
hi..
Actually you know what, I think summit has it backwards on their site where I looked it up last night. I just looked at compcam's site and you are correct. Its either that or i misplaced the -16 for a -12 after the 1412, that also is a V6 vs. V8 thing. Hmmm.....
Old Nov 18, 2003 | 11:18 AM
corvette90's Avatar
corvette90
Hi Scorp508
ive checked twice, Compcams, and summit, and they say, the CCA-1417-16
fits 87-97 Engines, 305-350cui..
i know, you have way more experience, in parts and engines, but since i have these items ship to Austria..which is not cheap, and takes time, i always check very carefully before ordering...
thank you for your statements, its great to have people who will talk and help :cheers:
oh, and yes you are right..when swapping some numbers, you come directly to the 4.3ltr engines...tried it, but dont ordered it :D
thanks again :)
Old Nov 18, 2003 | 11:23 AM
scorp508's Avatar
scorp508
Aww hell give it a shot!! :D
To rocker arms on L98
