Intake question
Old Nov 16, 2003 | 03:58 PM
darkred91's Avatar
darkred91
Default Intake question
I just took off my intake ports 2&4 were black is this bad injectors or what...tried to post a pitchure no luck.........NEED HELP 91 L98
Old Nov 16, 2003 | 04:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Intake question (darkred91)
Did you take off the intake base or just the runners?
You can check the resistance of your injectors to see if any coils are shorted out; they should read about 16Ohms.
At idle, put a finger onto the harness of each injector to see if they are pulsing with the same strength.
Pull the plugs to see if #2 & #4 are the same as the others.
If all these checks show ok and you have no leak-down problems, don't worry about the injectors.
Old Nov 17, 2003 | 12:24 AM
darkred91's Avatar
darkred91
Default Re: Intake question (65Z01)
I took off the base and runners....the base ports where black as well as the block ports.........
Old Nov 17, 2003 | 01:41 AM
65Z01's Avatar
65Z01
It's possible that the intake valves are leaking and you are getting blow back in those two intake ports.
Once again, check the spark plugs for further clues.
Once it's buttoned up you could run a compression check if nothing turns up otherwise.
Old Nov 17, 2003 | 09:08 AM
Aaron's 87's Avatar
Aaron's 87
Wet Black or Dry Black?
Old Nov 17, 2003 | 11:27 AM
darkred91's Avatar
darkred91
Default Re: Intake question (Aaron's 87)
Wet oil and gas Going to take off heads
Old Nov 17, 2003 | 12:03 PM
Aaron's 87's Avatar
Aaron's 87
How does the gasket look? Are you sucking fumes from the valley?
Old Nov 17, 2003 | 10:11 PM
Sam Lam's Avatar
Sam Lam
Look at your injectors.....what color are they? If they are a dark grey in color with a white circle at the top, you have Multech disease! From your comments, it appears two cylinders are different than the others. Like the previous post, check your resistance on each injector. If you have Multech injectors, send me an email and I can tell you what I did for my car.
To Intake question
