Setting Initial Timing on LT1
Old Nov 17, 2003 | 08:03 AM
bstirn's Avatar
bstirn
Default Setting Initial Timing on LT1
How do you set the initial timing on a 92 LT1
[Modified by bstirn, 1:08 PM 11/17/2003]
Old Nov 17, 2003 | 08:14 AM
96GS#007's Avatar
96GS#007
Default Re: Setting Initial Timing on LT1 (bstirn)
Install the Optispark correctly. There is no initial timing to set.
Old Nov 17, 2003 | 04:50 PM
bstirn's Avatar
bstirn
Can you check the timing on the LT1 .
[Modified by bstirn, 9:59 PM 11/17/2003]
Old Nov 17, 2003 | 08:51 PM
Goody's Avatar
Goody
No. It is controlled by the ECM. You could I guess if you went through the hassle of marking the balancer with TDC and then found some tape that is calibrated for that particular balancer/pulley and used it. Not much need since you can't adjust it anyway.....well except by programming the EPROM with different numbers.
Old Nov 18, 2003 | 08:24 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Setting Initial Timing on LT1 (Goody)
the balancer has no keyway in a LT1.. so I dont think it would give a accurate timing reading even if you went to the trouble of marking it (whereas it could slip and move a few degrees every now and then)..
I know it sounds weird.. and it caught me off guard when I was rebuilding the motor.. but thats the fact jack! :crazy:
To Setting Initial Timing on LT1
