LT-1 injector questions
Old Nov 17, 2003 | 09:07 AM
fiddleplayer's Avatar
fiddleplayer
Default LT-1 injector questions
I just purchased a 94 that has a leaking injector. the engine is stock. Would the SVO #19 injectors work as a direct replacement for the stock injectors without any tuning? I just picked it up last night and have not checked the fuel pressure yet. I've had an 86 for the last 4 years and know nothing about the LT-1 tuning yet. So I'm just starting. Any suggestions on a scan tool? I used to use a diacom but it is no longer available.
FP
Old Nov 17, 2003 | 10:25 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: LT-1 injector questions (fiddleplayer)
no.. stock LT1 injectors are 24# Multi-tec's.. I heard the 24# SVT's are nice replacments..
Old Nov 17, 2003 | 11:22 AM
93aqua's Avatar
93aqua
Default Re: LT-1 injector questions (BluByU)
I replaced mine with the #24 from ford. They work Fine, if you do a search you will find that the ford ones are favored and the Accell ones you need to stay away. Check out ebay, they are usually on sale. Also check the how to section, thats what i used and it went pretty smooth.
Old Nov 17, 2003 | 12:56 PM
fiddleplayer
Default Re: LT-1 injector questions (93aqua)
Sorry, I meant to say #21. I went to the 5-0 motorsports website and the #21 were recommended. Is this because the want to choke us down so they can win?
Which #24 should I order? There looks to be about 4 or 5.
you didn't have to reprogram anything? I had read in the scan and tune that the fuel pressure needed changed as well as the injector pulse width.
FP
[Modified by fiddleplayer, 12:05 PM 11/17/2003]
Old Nov 17, 2003 | 01:13 PM
93aqua's Avatar
93aqua
No, the computer automaticlly adjusts.
Old Nov 17, 2003 | 03:46 PM
fiddleplayer
http://www.fiveomotorsport.com/Injector_SetsFORD.asp
Which ones?
I had read a thread in the tune and scan archive that recommended the 21 lb so thats what I ordered last week. I will not be racing, so will the 21's be sufficient. I also read that the fords were rated different, so is it comparable that the ford 21's equal the chevy 24's?
Old Nov 17, 2003 | 08:02 PM
dizwiz24's Avatar
dizwiz24
FYI, not all LT-1's have 24's. Correct me if Im wrong I believe the 92 and 93's have 22's.
But in this case, yes, the 94 LT-1 I believe has 24's.
I didnt know the computer automatically adjusted for different size injectors (confused). Might want to double check that.
I heard it also throws off your instant MPG, just so you know.
Old Nov 17, 2003 | 09:28 PM
Switch's Avatar
Switch
Default Re: LT-1 injector questions (dizwiz24)
The PCM will learn, but not at WOT or during open loop before the engine warms up. Of course the PCM will forget everything when it loses power and it will have to relearn. Idealy, the PCM would need to be reprogrammed with any different injector. A lot of folks are getting away with not doing it though.
I have lots of good used 24's if you need some.
Gordon
Old Nov 18, 2003 | 08:00 AM
fiddleplayer
Default Re: LT-1 injector questions (Switch)
Received and installed the 21 lb injectors last night. It runs okay, jumped right up to 120 with no problems. Since I just purchased it I have no history to tell if the performance is less. I'm taking it to see if it passes emissions today. Will advise results.
Yes, it seems like the instant milage is reading low now. I've only driven it 30 miles since I bought it. The saftey inspection sticker is expired.
Gordon, I think you sent me an IM yesterday and I replied. Just to confirm, Yes I will take a set. That way I can go back to the originals.
I did notice the opening on on the 21's was considerably smaller than the 24's.
FP
Old Nov 18, 2003 | 08:11 AM
96GS#007's Avatar
96GS#007
The computer only adjusts at idle and part throttle. At WOT, using different injectors can result in too rich or too lean of a condition. Having said that, the difference is typically so minor it doesn't matter on a basically stock engine unless someone really goes overboard on injector size and/or fuel pressure.
Old Nov 18, 2003 | 08:20 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: LT-1 injector questions (96GS#007)
and ALL LT1's have 24# injectors... L98's have 22# and LT4's have 26# injectors.. I'm not sure about LT5's.. although i'd love to learn! :reddevil
Old Nov 18, 2003 | 12:35 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
DO NOT buy Accel or Python. They're both ghetto. :nono:
Old Nov 18, 2003 | 03:08 PM
fiddleplayer
Default Re: LT-1 injector questions (onedef92)
still failed emissions. NOX :banghead: :banghead: :banghead:
Old Nov 19, 2003 | 12:15 AM
robert kirk's Avatar
robert kirk
"All lt1's have 24# injectors" is not true. I have a 92 lt1, and the stock factory injectors are 22#. I just installed a new set of 24# and am in the process of having ski-dwn-it, jesse, burn a new chip. I have a 3inch slp cat back exhaust and a k&n filter. After installing the 24# the car is running very rich. The exhaust is black and sooty, and the motor is slugish at low rpm. It has not tripped any codes but you can feel the throtle response is not what it should be. Above 3 grand it is a bullet. So yes changing injectors does make a diff, and the comp does not always compensate on a 92 lt1 for sure. Robert :cheers:
Old Nov 19, 2003 | 08:05 AM
96GS#007's Avatar
96GS#007
The LT4 injectors are rated at 28# :)
Old Nov 19, 2003 | 08:25 AM
Z06_BluByU's Avatar
Z06_BluByU
ok than does anyone know for SURE what injectors the 1993 corvettes have?
I was told 24# and that all LT1's have 24#'ers.. My chip is being burned as we speak!! :eek:
Old Nov 19, 2003 | 11:06 AM
fiddleplayer
I ordered new cats today and will put the original injectors back in. I got almost the same readings on the emissions with both sets.
FP
To LT-1 injector questions
Old Nov 19, 2003 | 05:03 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
I just installed Ford #21 injectors on my LT1 (92) , from five O motorsports and the work great the only thing is to make shure the fuel rail clip is in the top groove of the injector, if you do not do this you will have a vacume leak at the bottom bung.
The # 21 are fine as the Ford rates their injectors at a lower pressure so it should be fine at the higher pressure.
:cheers:
Old Nov 19, 2003 | 05:32 PM
TheStef's Avatar
TheStef
Default Re: LT-1 injector questions (grapeknutz)
Isn't Gm pressure rated at 40psi and ford at 36psi ?
Old Nov 19, 2003 | 05:54 PM
fiddleplayer
That's where I got mine. Are you experiencing erroneous readings on your instant and average milage with the #21's? I did use the upper retainer ring slot on the injectors. I have a leaking injector in my 86 and was going to xfer the #21 to it and replace the originals in the LT-1. At this time I'm still trying to pass emissions with the LT-1.
