Stalling Problem
Old Nov 17, 2003 | 09:18 PM
somethingerother's Avatar
somethingerother
Default Stalling Problem
Whenever I take my 84 vette somewhat quick (not that fast at all)on a turn it will lose all response from the gas pedal. It also dies when I try to floor it and get the tires spinning from a dead stop, or while doing a 360 from a stand still. It doesnt happen as much on a full tank as it does with about a half a tank or less. I noticed when at a dead stop it will stall when it nears 4000rpm. I'm not really sure why this happens but I'm betting its probably a common problem.
Old Nov 17, 2003 | 09:19 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Stalling Problem (somethingerother)
Sounds like you are starving the fuel pump.
Old Nov 18, 2003 | 02:10 PM
Unriced's Avatar
Unriced
I had the same problem, replaced the fuel pump and problem solved..
You should notice better all around performance too. I did..
To Stalling Problem
