LT4 knock module
Old Nov 17, 2003 | 09:28 PM
jodyeastman's Avatar
jodyeastman
Default LT4 knock module
I see this sometimes come up in discussions. Can someone explain to what this is and is it something us LT1 guys should upgrade to. Thanks in advance. :smash:
Old Nov 17, 2003 | 11:22 PM
comp94's Avatar
comp94
Default Re: LT4 knock module (jodyeastman)
GM uses this knock module in the lt-4' s because it is less sensitive to engine nooises. the reason they did this is because when they put the roller rockers into the lt-4 the ecu would sense false knock due too the nooise of he roller rockers. alot of the f-body guys do this when they install headers or roller rockers because the lt-1 knock module will pick up false knock and retard the timing. with the mods that you have listed in your sig i think that youu will be fine with the stock lt-1 knock module.
Old Nov 18, 2003 | 08:54 PM
lspalding's Avatar
lspalding
Default Re: LT4 knock module (comp94)
:iagree:
Old Nov 18, 2003 | 09:12 PM
Lone Ranger's Avatar
Lone Ranger
I tried the LT4 knock module in my ECM and it didn't make any difference, and actually the car seemed to run better when I removed and put the LT1 module back in.
Old Nov 19, 2003 | 11:37 AM
STL94LT1's Avatar
STL94LT1
Default Re: LT4 knock module (NavyVet)
Unless your LT1 is a 96 with ODB-II, it won't communicate properly with the ECM. The LT4 module (GM #16214581 & AC Delco #216-67) will only communicate properly with a 1996 ODB-II computer. :flag
The LT4 knock module seems to be working in my '94 LT1. :skep:
Old Nov 19, 2003 | 01:22 PM
87Z-ya's Avatar
87Z-ya
On the dyno my car was seeing knock at~4000 rpm's no matter how much timing was taken out it would still see knock. Put in the lt4 module and mysterious knock went away. The lt4 module works fine with my 94 ecm
Old Nov 19, 2003 | 03:28 PM
STL94LT1's Avatar
STL94LT1
NavyVet, the LT4 knock sensors will only work on OBDII cars, but the LT4 knock module will work on both OBD1 and OBDII cars. Maybe this is where you are getting confused.
Also, the only OBDI Vettes that have a removable knock module are the 94/95's.
[Modified by STL94LT1, 2:31 PM 11/19/2003]
Old Nov 19, 2003 | 11:52 PM
comp94's Avatar
comp94
Default Re: LT4 knock module (STL94LT1)
:iagree:
because 94 was the first year of obdII style connector in the vette. also if im not mistaken 94 was the first year that they used an EEPROM all years prior to that was an EPROM
Old Nov 20, 2003 | 12:08 AM
Alex D's Avatar
Alex D
Actually much of OBD II was already introduced in the 94 model year.
Old Nov 20, 2003 | 12:14 PM
comp94's Avatar
comp94
Default Re: LT4 knock module (Alex D)
Actually much of OBD II was already introduced in the 94 model year.NavyVet, the LT4 knock sensors will only work on OBDII cars, but the LT4 knock module will work on both OBD1 and OBDII cars. Maybe this is where you are getting confused.
if memory serves me correctly the only thing that was OBDII on the 94/95 models was the 16 pin connector while the actual ecu was still OBD I. if you try to use a generic OBDII scan tool on these year vettes it will read not able to link with ECU
Old Nov 20, 2003 | 01:42 PM
NavyVet's Avatar
NavyVet
STL94LT1 - thanks a lot. You're absolutely right. Open mouth, insert foot..... when I should have been putting my brain into gear first.
The LT4 knock SENSOR is what can't be used on OBD-I. Thanks again, Paul :flag
To LT4 knock module
