How many O2 sensors??????
Old Nov 18, 2003 | 09:28 AM
Kizmo's Avatar
Kizmo
Default How many O2 sensors??????
I don't want to sound dumb, but what is the exact count of O2 sensors on a 95 LT1? I have read posts that mention sensor's or replace all the sensors, so I am really confused. I only know of the one on the left exhaust pipe. Are there others?
Thanks.
Old Nov 18, 2003 | 09:47 AM
GS919's Avatar
GS919
Default Re: How many O2 sensors?????? (Kizmo)
I believe that there are 4, 1 before and 1 after each cat. But that is on a '96.
[Modified by GS919, 8:49 AM 11/18/2003]
Old Nov 18, 2003 | 09:48 AM
ZylaRace's Avatar
ZylaRace
If you didn't know, 95 is an odd year. It is part OBD1, part OBD2.
OBD1 engines have at least one.
OBD2 engines will have at least 2. 3 would be typical, on a V8.
I'll wait for another 95 owner to chime in.
Old Nov 18, 2003 | 03:26 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: How many O2 sensors?????? (ZylaRace)
'92-93 LT1 Engines have two, one before each catalytic convertor - 1 wire type
'94-95 LT1 have 3, one on drivers side pre-cat, two on passengers side before and after cat. Only the front ones are truely functional and the rear one can be simply unplugged without a code or any other effect. 4 wire heated O2 sensor.
'96 LT1/4 has 4, one before and one after each of the cats. The rear ones can be bypassed with O2 sims. 4 wire heated O2 sensor.
Old Nov 18, 2003 | 07:01 PM
Trey96LT1's Avatar
Trey96LT1
Default Re: How many O2 sensors?????? (Vette92)
On the 96's will sims have any effect on performance or milage?
where can I buy sims?
My car has 95k miles and seems to lose milage lately and with o2 sensors costing about $50 each it can get expensive replacing all 4
Old Nov 18, 2003 | 11:15 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: How many O2 sensors?????? (Trey96LT1)
If I were you, I would just replace the front ones. The rear ones are only for checking to see if the cats are working. I think sims are around $200 and are generally used only for those running without cats to fool the computer.
Old Apr 11, 2024 | 10:48 AM
carguy65's Avatar
carguy65
Are we sure a 1993 Corvette LT-1 has two O2 sensors? I have read 3 and everyone that comments or asks this question has a 92,94,95, WTF nobody has a 93? Hopefully I can get the correct answer!!
Old Apr 13, 2024 | 08:15 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Please start a new thread on this topic.
To How many O2 sensors??????
